Head Swap - Anything else I need to know?
Tripoli
208
Dallas, TX
I'm getting ready to put Fox Lake stage 2 heads on my car, and I want to make sure I have all my bases covered.
I'll be referencing this thread, this thread, and my Haynes manual for some misc. info as needed.
The general plan is to remove and reinstall the engine with the transmission and Hooker long-tube headers attached. I'm assuming this is possible, so please let me know if it is not.
Supplies (Am I missing anything?):
- I have all tools I could possibly need, including in./lb. and ft./lb. torque wrenches, harmonic balancer puller, etc.
- 2 Oil changes.
- 4 quarts Mobil 1 ATF (I plan on draining the transmission because it'll be tilted back while removing from the car and still attached to the engine.
- Coolant
- Assembly lube (I plan on using 50 weight oil.)
- RTV (I plan on using copper for everything unless someone can give me a compelling reason to use a different variety.)
- Lacquer thinner (to clean off ARP stuff before installing.)
- Brake cleaner (to clean off engine block where head gaskets seal)
- Ziploc Bags and Sharpie to label bolts and such.
- ARP head studs, nuts, washers, and lube (256-4201)
- Head gaskets (Ford 4C2Z-6051-BA left & 4C2Z-6051-AA right)
- Heads - (I will be reusing my VT Stage 2 NA cams, and keeping stock cam gears.)
- I already have ARP harmonic balancer/cam bolts from cam swap.
- I already have new-ish timing chains from cam swap @ about 90k miles.
- Crank pulley install bolt.
- Anti-seize for spark plug threads.
Disassembly:
- Support car on ramps or jack stands.
- Disconnect battery
- Disconnect all electrical connections to engine and transmission.
- Disconnect clutch cable.
- Disconnect headers from X-Pipe.
- Disconnect fuel and vacuum lines from engine.
- Break harmonic balancer bolt loose.
- Remove serpentine belt.
- Drain transmission, engine oil, and radiator.
- Remove shifter.
- Remove driveshaft.
- Unbolt intake manifold from heads and remove with upper intake and injectors still installed.
- Attach engine hoist to ears at back of block and to studs at the front.
- Remove transmission mount.
- Detach steering shaft from rack.
- Unbolt A/C compressor and zip-tie to K-member or sway bar.
- Unbolt power steering pump and reservoir and zip-tie out of the way.
- Unbolt motor mounts from K-member.
- Remove engine & transmission from vehicle by lifting upwards and forward. (If necessary, remove headers first by dropping the K-member. If necessary, unbolt transmission from bellhousing and remove.)
- Rest engine on floor with boards supporting weight under transmission, bellhousing, and oil pan.
- Drain coolant from block.
- Remove spark plugs. (They only have 15k miles, so I plan to reuse and check to make sure gap is still good: 0.048" - 0.050")
- Remove headers, if not removed earlier.
- Remove harmonic balancer and set crank in safe mode (Keyway at 9 or 12 o'clock).
- Remove value covers.
- Remove timing chain cover, being careful not to damage gaskets.
- Remove timing chain tensioners.
- Remove timing assembly.
- Remove cams and gears, making sure my Romeo caps stay matched to their original positions.
- (For first-time use of ARP studs.) With stock heads and gaskets still in place, lube and install ARP studs, washers, and nuts. Torque head studs to 30, 60, then 90 ft.-lbs. Loosen and repeat 5 times. (This is done on old heads and gaskets to prevent unnecessary repeated compression of the new head gaskets.)
- Remove stock PI heads.
- Gently clean engine block-side gasket surfaces with brake cleaner.
Reassembly:
- Lube, install, and finger-tighten ARP head studs into block.
- Place head gaskets.
- Make sure heads have appropriate oil holes plugged or not.
- Place heads.
- Lube, install, and finger-tighten head stud washers and nuts.
- Torque head studs to 30, 60, then 90 ft.-lbs. Sequence per side:
7-3-1-5-9
10-6-2-4-8
- Place followers in heads.
- Make sure crank is still in safe mode (Keyway at 9 or 12 o'clock).
- Install cams and retainer caps. Tighten cam retainer bolts to 71-106 inch-pounds.
- Torque cam sprocket bolts to 95 ft.-lbs.
- (Too tired to finish this now, but the rest is basically the reverse of above.)
Please let me know if there's anything important I'm missing. I will update this original post as I get all the info I need.
With these heads (which include high-load Comp valve springs), the stock shortblock, and the mods listed in the link in my signature, how fast can I reliably spin the engine naturally-aspirated? I regularly tap my 6,500 RPM rev limiter with my current setup. I've heard a number of people say that 7,000 RPM is fine without a power adder.
  • Sponsors(?)
CobraRed_96_GT
1,421
UCSD/La Jolla
You can get the engine out with LT's, it's just hard. But you cant set it on flat ground, the LT's would hit first - and you dont want it resting on those. Get some wood and block it up at the tranny output shaft, the bell housing, and just in front of the oil pan or on it.
I'd also suggest a wire wheel to clean off your piston heads while the cyl. heads are off.
I'd drain the whole block, do the surgery, then replace all the fluids. You need to run you engine for a min or so then refill the coolant at the thermostat location, run it again and fill it at the overflow.
I wouldn't rev over 6800 if i were you, with stage two's you shouldn't see much higher gains after that anyways
rugster
156
yes drain the oil before you work on it...then change it again after the first 100 miles.
you will need at least 2-3 gallons of coolant (not pre-mixed)
drain the coolant out of the block using the block drain plugs. you will need to remove the motor mounts for this as these plugs are behind them. They are large hex heads.
attach hoist in front using the 2 holes in the valley in the front, and in back there are 2 "ears" you can use in the corners.
the head studs I dont know off the top of my head, sorry!
CobraRed_96_GT
1,421
UCSD/La Jolla
get anything that decided to float around the oil pan out. the assembly lube should protect anything from damage. also it will dissolve in the oil pretty quickly after contact, you want that out.
so i should fill it with a mineral oil for 100 miles before i put in my synthetic Mobil 1?
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Visit site
If you follow the thread above, and you should be fine.
You seem to have a pretty good grasp of things:nice:
I outlined the thread above assuming that you can take it down, and it is in order to build it back up:)
When you pull your heads, just check your NEW headgaskets with the old ones.
I would suggest priming the engine before you start it up, or at the very least (assuming only 2-3 days for downtime), pour oil all over the heads/cams/timing chain to get them a little lube.
If you can get a friend to help, it will be great! Also, if you know someone with a 4.6L, it can be good to reference when you are putting it back together (vac. lines/spark plug wires).
Don't overtorque the spark plugs either.
Good Luck!
rugster
156
as he said above you wana get anything that is in the pan flushed out, as well as make sure there aren't any shavings or anything like that. Just cheap insurance:nice:
rugster
156
and the drain plugs are allen key type...I dont know the size off the top of my head sorry, but it is pretty big. Also, you asked if you could pull it with long tubes and you can as long as you have the type where the steering shaft doesn't go between the down pipes. If thats the case then obviously you have to pull the drive side header. If you have the longtubes where the steering shaft is outside the downpipes then you should be able to squeeze it outta there with them attached.
One piece of advice, if the bottom of the longtubes are catching on the K member...drop the K member, it will make everything very easy when you are putting it all back together. Good luck man!
rugster
156
just read the bottom of your post....please DO NOT tighten your cam caps to 95 ft lbs, that should be INCH POUNDS!!! you would be replacing those heads in a few days if you stretched the aluminum by over-tightening.
CobraRed_96_GT
1,421
UCSD/La Jolla
I hope so...I think the caps are like 108 in lbs.
This was is the linked thread tho:
Crankshaft Bolt: 118 ft. lbs or see below.*
Camshaft Bolts: 82-95 ft. lbs*
Intake Bolts: 18 ft. lbs
Valve Cover Bolts: 89 inch lbs. (71-106 inch lbs.)
Timing Cover Bolts: 19 ft. lbs
Spark Plugs: 13 ft. lbs**
Arm Tensioner, Power Steering Pump, Water Pump Pulley Bolts*: 19 ft. lbs
* - A drop of loc-tite may be suggested.
** - A small dab of anti-seize on the threads may be a good idea.
rugster
156
Cam caps should be 89in lbs. INCH POUNDS-- dont read that wrong :D
The deal with the torque sequence on the head bolts, is they are torque to yeild bolts. You are actually stretching the bolt once installed- this is the reason you cant reuse them.
If you stretched those to 89 FT LBS I guarantee you wouldn't be happy with the results, whether they are torque to yield or not.
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Visit site
Cam Bolts - Front of camshaft (hold the timing gears to camshaft).
Cam Caps - Top of camshaft (hold the camshaft onto the head).
Thread starter Similar threads Forum Replies Date
68stang351 Is there anything not normal about doing this head swap? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 1
R 351-408 swap with raised port heads what header 1996 - 2004 SN95 Mustang -General/Talk- 3
T Gt40 head swap with windsor heads???? The Welcome Wagon 2
95TT347Cobra BEST SWAP OPTIONS! 05 GT 4.6 3v (Threw Rod), I have a 4.6L 2v out of an 04 GT and 4V in A mark. Suggestion? 2005 - 2009 Specific Tech 2
ClevelandTim Engine Heads and Cam Swap. Am I doing it right so far? Fox 5.0 Mustang Tech 2
ClevelandTim Engine Head & Cam Swap Parts Fox 5.0 Mustang Tech 5
K Engine swap help Other Auto Tech 1
J Engine 5.0 aluminum head install Fox 5.0 Mustang Tech 10
B HELP!!!! New edge head swap w Merc 1996 - 2004 SN95 Mustang -General/Talk- 0
Z Engine 1998 split port head swap SN95 V6 Mustang Tech 0
Y Engine Heads and Intake Swap Problems :/ Fox 5.0 Mustang Tech 16
T Engine 1990 5.0- Overheating and Smoke after Head Swap (Need advice ASAP) Fox 5.0 Mustang Tech 3
L PI head swap disasters 1996 - 2004 SN95 Mustang -General/Talk- 1
1989LXFOX Engine SVE Aluminum Head Swap Question Fox 5.0 Mustang Tech 8
S Engine 1995 gts 331 stroker head swap questions 1994 - 1995 Specific Tech 0
fredfifty Engine swapping used heads Fox 5.0 Mustang Tech 1
S Porting E7 Heads And Intake Or Gt40 Swap? Fox 5.0 Mustang Tech 8
scottiedog Intake Swap Anybody Know Why A 4v Intake Wont Fit A 2v Head SVT Tech Forum 3
sen2two Rough Idle After Head Swap 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 7
M Pi Head Swap Break In Procedure. SN95 4.6L Mustang Tech 6
Miami1985 1985 302 Head Swap Fox 5.0 Mustang Tech 3
P Pi Head Swap 1996 - 2004 SN95 Mustang -General/Talk- 0
O Engine Whats Needed For A Gt40/gt40p Head Swap? Fox 5.0 Mustang Tech 11
G 96 Gt Pi Head Swap - Help! SN95 4.6L Mustang Tech 13
madspeed Engine Head Gasket Swap... Questions Within Fox 5.0 Mustang Tech 93
1 Engine 95 Gt Head Etc Swap 1994 - 1995 Specific Tech 2
1 Gt40p Head Swap 1996 - 2004 SN95 Mustang -General/Talk- 0
bhuff30 Pi Head Swap: Worth The Effort? SN95 4.6L Mustang Tech 9
CWBx Engine Difficulty Of Head Swap? 2000 V6 SN95 V6 Mustang Tech 2
D Too Much Mileage For Head Swap? Fox 5.0 Mustang Tech 5
90lxwhite Gt40 Head Swap Question 1994 - 1995 Specific Tech 4
bbrewer5 Engine 95 Gt40p Head Swap Valve Noise. 1994 - 1995 Specific Tech 14
skiwesser11 Blown Head Gasket, Should I Swap Cams Is My Q 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 5
Blck98gt Cam And Head Swap Question.. SN95 4.6L Mustang Tech 7
AZmustang98 PI head swap vs NPI cam swap SN95 4.6L Mustang Tech 6
E pi heads swap SN95 4.6L Mustang Tech 0
G Cylinder head swap Fox 5.0 Mustang Tech 23
O opinions on a head swap SN95 4.6L Mustang Tech 2
demented22 how to identify a pi head swap SN95 4.6L Mustang Tech 13
R Tips for Timing after PI Head swap SN95 4.6L Mustang Tech 2
B PI HEAD SWAP SN95 4.6L Mustang Tech 3
J Head Swap! 289->351w Classic Mustang Specific Tech 8
D Pi head missing parts swap SN95 4.6L Mustang Tech 1
281pony Is it worth my $$ to swap heads? Fox 5.0 Mustang Tech 13
sneaky98gt P&P NPI Heads or Swap to PI Heads 1996 - 2004 SN95 Mustang -General/Talk- 17
MyHoFoSho Head Swap Questions? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 14
G T-5 swap or Heads? 1994 - 1995 Specific Tech 7
Ruffellbaker PI Cam and Intake swap gasket kit, no heads SN95 4.6L Mustang Tech 4
horseballz "Best Practice" Head Gasket Swap? Opinions? Classic Mustang Specific Tech 5
0 GT40P head swap problems.... Fox 5.0 Mustang Tech 6
