Head torque ???
On mine I've always done 85 on top 80 on the lower row. I use moly lube under the head bolt washers and under the bolts. Start in the middle, in steps from 40ft lbs, 60ft lbs, then 80ft lbs. I then go back and do the top row another 5ft lbs. I usually wait anywhere from an hour to maybe a whole night (depending on the amount of alcohol consumed :D ) then go back and check them all again. Make sure you don't overtorque the lower intake either. I put some thread sealer on the bolts and torque them to 12ft lbs. It'll take 4-5 passes to get them all torqued evenly. Good luck.
Dont forget to put some sealer on the lower bolts since they go into a water jacket, I used some permatex (but I am sure there is a better sealer as permatex is so thick it could mess up trq readings, I just did each side quick so the tex would not get hard).
