Head torque
  • Thread starter Thread starter trendkilllx
  • Start date Start date Jun 11, 2004
First Prev 2 of 2
saleenx029
117
Cincinnati, Ohio
Jun 12, 2004
#21
  • Jun 12, 2004
  • #21
torque
My two motors that I have been assembling the last couple days I came across this same scenario and this is what I did:
Motor #1= I used ARP bolts 170,000 psi and torqued them to 70 foot lbs all the way around. Fel-Pro stock style gasket. This is a mild combo so I wanted to see how it holds up with the lesser torque.
Motor #2= Same kind of ARP bolts, torqued them all to 80 ft lbs all the way around, Fel Pro Hi perf Blue Line (40 bucks each) This is the motor to be raced hard so went with the higher torque values, we will see how each holds up soon. Thats my 2 cents.
EMW150
2,020
Roaring Spring,PA
Jun 12, 2004
#22
  • Jun 12, 2004
  • #22
Michael Yount said:
EMW - your combo looks like it totally rocks. Can you give us the highlights of the new combo in the works?
Thanks, I'm still working out traction problems but it's coming around. The 331 I'm currently running should be around 10.60s or so in the cool air this fall with decent traction. The new combo is a 342 solid roller, gas ported pistons, 0-balance. The goal is 10 flat naturally aspirated on pump gas and street legal.
EMW150
2,020
Roaring Spring,PA
Jun 12, 2004
#23
  • Jun 12, 2004
  • #23
trendkilllx said:
Well it seems that most people i've talked to said go 80 on top and 70 on bottom. I think thats right as it is what AFR said, and as well as the felpro head gasket instructions. I got confused because the ARP instructions. Does the moly lube also work as a sealer. thanks
Yeah, 80 long / 70 short should work well for you. I go less on the long bolts because I only torque my intake to 14 lbs and because I run head studs instead of bolts. Some guys go up to 24 lbs on the intake so in that case I would definately go 80 on the long bolts. Also the moly does not work as a sealer. ARP sells a different sealer for the bottom bolts. It works fine on head bolts just don't try it on studs.
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Jun 12, 2004
#24
  • Jun 12, 2004
  • #24
Sounds like fun - keep us posted.
First Prev 2 of 2
Engine Brackets for Gt40 heads with ac and ps?
  • Xavierg208
  • Nov 14, 2025
Fox 5.0 Mustang Tech Nov 16, 2025
limp
D
4.6L 4 valve Sleeve
  • DangStitches
  • Oct 10, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 20, 2026
DangStitches
D
Cooling Jacket Pitting Idea's?
  • BoostedRed89gt
  • Aug 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2026
Mustang5L5
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
9
Will I feel a difference
  • 90Stanger302
  • Mar 12, 2026
1965 - 1973 Classic Mustangs -General/Talk- Apr 13, 2026
