Header Bolt Question
  • Thread starter Thread starter mnmrmstd
  • Start date Start date Jun 30, 2006
M
mnmrmstd
  • Jun 30, 2006
I'm installing a set Ford shorty headers (M-9430-P50) on GT-40 heads (1989 GT). I've seen the header bolt size for this application listed as both 3/8-16 " x 3/4" and 3/8-16 " x 1". The key dimension here is the underhead length: 3/4" or 1" ? Thanks for the assistance.
TheBocSez
652
Converse, TX
Jun 30, 2006
  • Jun 30, 2006
Get the 1". More threads into the head and better clamping force. Tighten down and drive around for a few days, then tighten em up again while the engine is warm and your done.
If using aluminum heads, use anti seize and the recommended torque specs.
vristang
4,933
101
124
Seattle
Jun 30, 2006
  • Jun 30, 2006
1" would be good, as long as it doesn't bottom out inside the threaded hole.
I am not sure what the actual length would be on those?
Do you have any other bolts laying around to use as a guide for length.
Maybe you could poke a stick or something in the hole, then measure the length of stick that would fit in the hole?
jason
TheBocSez
652
Converse, TX
Jun 30, 2006
  • Jun 30, 2006
I think the 1" would be ok, I believe the headers he's using have a 3/8 flange so you lose 3/8" just to the flange plus just a little more for gasket thickness. That would probably only leave a 1/2" or so to screw into the head. (sorry, not good with fractions)
Exhaust 1 3/4” Long Tubes on a Fox Body AOD – Easiest route?
  • 5.0 Mike
  • Mar 19, 2025
2K
Fox 5.0 Mustang Tech Mar 21, 2025
5.0 Mike
9
Forced Induction Prepping for supercharger on non-stock build
  • 91fox427
  • Nov 25, 2025
Fox 5.0 Mustang Tech Jan 5, 2026
Qtrhrse23
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
1973 Headers
  • Stang_1973
  • Mar 11, 2025
1965 - 1973 Classic Mustangs -General/Talk- Apr 1, 2025
H
1966 mustang starter and pulley troubles
  • Hotrods4ray
  • Sep 24, 2025
1965 - 1973 Classic Mustangs -General/Talk- Jan 10, 2026
Realmongo
