Header/Clutch linkage help please!
69Mach351
39
I have hedman's longtube coated headers (model 88308)
Here they are http://store.summitracing.com/default.asp?target=eadvsearch.asp&SearchType=Engine
I am putting them on and the clutch linkage (in my 69 mach one-351w-4spd) must be removed. I am having a helluva time getting it back in with the header, we have tried jacking the motor up (removed mount bolts) and holding the header in place for manuverability rather than bolting it up. Tomorrow we are going to pick the motor up completely and move it over a couple of inches to get it in unless there is an easier way. The Instructions are crap so can anyone give me some advice here?
On my '69 I put the transmission and the engine together and then dropped them in the car. When the engine was almose seated in the mounts, I slipped the headers in. I bolted them down and then realized that they pinched the clutch fork. It wouldn't even move and the headers wouldn't seal. After moving the headers out of the way, I ended up using a dremmel tool and cut the outer part of the fork (where the return spring attaches) as short as I could without getting rid of the spring hole. I basically removed the 'ears' and cut the fork so that it tapers down at the spring end. I put a little notch in the side of the fork so that the return spring would have somewhere to sit (i put it through the hole but the notch kept rest of the loop from moving around and touching the header). I also dented the crap out of the offending header tube - use a propane torch, it makes the denting a little easier. I now have enough clearance that the clutch fork will move freely and not touch the header (barely).
