Header gasket install suggestions?
  • Thread starter Thread starter MUSTANGJOE
  • Start date Start date Sep 25, 2004
1 of 2 Next Last
MUSTANGJOE
Silver Stanger
1,644
17
59
Sep 25, 2004
  • Sep 25, 2004
Hey guys!
I'm gonna be changing my header gaskets this week. Its the second time this year and they blew again. Starts by a little ticking then gets luder and totaly ruins the performance of your car! Anyways, what gaskets should I get? I was thinking felpro. I have bbk shorty's 1 5/8. This time I bought those stage 8 locking bolts from 50resto. How do you install these? Should I tighten the bolts drive a little then retighten them or do I just tighten once on the install and thats it? Also should I use and high temp silicon along with my gasket or is just the gasket fine? I wanna get rid of this problem, so I wanna do it right!! Thanks for any info
5.0Droptop
...all those nights we shared, and you're a dude??
Special Agent Mukity-Muck Whats in Charge Round Here
May 15, 2002
1,785
1,130
233
Indiana
Sep 25, 2004
  • Sep 25, 2004
I really like Mr Gasket Ultra Seal header gaskets. I hate the felpros, I have had no luck with them.
G
go4it
206
Virginia
Sep 25, 2004
  • Sep 25, 2004
I used the 1415 felpro and haven't had any problems with them. Didn't add anything to them and have not retightened the bolts. Probably wouldn't hurt to recheck the bolts though.
MUSTANGJOE
Silver Stanger
1,644
17
59
Sep 25, 2004
  • Sep 25, 2004
Were can I get the droptop? Summit?
MUSTANGJOE
Silver Stanger
1,644
17
59
Sep 25, 2004
  • Sep 25, 2004
I want a good seal, I heard of people just adding alittle around the exhaust holes and the bolt holes.
IndyBlk5.0
1,122
New Whiteland, IN
Sep 25, 2004
  • Sep 25, 2004
You can get the mr gasket header gaskets at autozone in their performance section.... These are a multilayered gasket, with wire mesh in the center...
IndyBlk5.0
1,122
New Whiteland, IN
Sep 25, 2004
  • Sep 25, 2004
Also, these gaskets are just like any other gaskets. I ussually get the outermost bolts in first (the far back and the far front) then I loosly put all the bolts in. This really helps if you have individual flange headers. Remember, the header gaskets are just like any other gaskets, they like the be sqeezed from the center out.
89CopCoupe
Banned
Feb 17, 2004
606
Post Count City
Sep 25, 2004
  • Sep 25, 2004
I know the aftermarket exhaust companys love saying: "direct-fit" and "bolts right in" ... but for the most part they don't exactly.
If your mid-pipe is binding (when you go to install the headers) it puts stress on header flange and typically leads to premature gasket failure. The headers should bolt right up without any pulling or prying on the pipes ... if they do, take it to a friend or exhaust shop and get the mid-pipe cut and rewelded
I use the supplied bolts then lock two wrenchs together to give me better torque on the bolt head. Tighten them, run the car hot ... let it cool down a bit and then retighten them. Then check them periodically. Works for me.
M
mustangman33
262
Chicago, IL
Sep 25, 2004
  • Sep 25, 2004
I had that same issue blowing header gaskets till I got the cooper header gaskets, had em for like 2 years and never had a problem.
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Sep 25, 2004
#10
  • Sep 25, 2004
  • #10
I'm a big fan of the Ultra Seal from Mr Gasket as well.
I'm glad to see that this was mentioned. Most people don't do this when installing new gaskets and end up with a leak prematurely. Also, don't tighten them too tight right off the bat. Don't forget that they may need to be re-torqued at least once or twice after installation. Even with the locking fasteners. They're going to compress a little when hot and get loose when the cool down. Stone cold is the best time to re-torque them.
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Sep 25, 2004
#11
  • Sep 25, 2004
  • #11
I'd add - pull the shorties off to help with alignment. If you leave them tightened at the ball/socket joint, and then try to tighten them back at the head interface, that can create seal problems. And as long as you have them off, lay a straight edge along the flange and see if they are true/flat. Most aren't. For a few bucks your local machine shop will mill a couple hundredths off the flange to make them true -- and they'll seal like a champ, and bolts will tend to stay tight.
LASTFOX
105
RI
Sep 25, 2004
#12
  • Sep 25, 2004
  • #12
Felpro 1415's...Stage 8 lockers...no problems here!
MUSTANGJOE
Silver Stanger
1,644
17
59
Sep 26, 2004
#13
  • Sep 26, 2004
  • #13
Guys, So I sould intstall the gasket with the locking bolts, drive a little then wait till the car cools down and then retighten them right? So with these stage 8 bolts how can i do this? They will be locked, I won't be able to move them anymore. Unless I dont add the locks later, but is it possible? Thanks
87TTopGT
173
#14
  • Sep 26, 2004
  • #14
My headers came with a copper gasket and I have no leaks. When I first installed them they had a slight ticking sound, but after driving it and letting it cool and retightening all is well!
P.S.- Anyone, is it even POSSIBLE to blow a copper gasket?
R
Ray@VSK
355
#15
  • Sep 26, 2004
  • #15
I always put a lite coat of black gasket sealer around the water ports, always had good luck
Gearbanger 101
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Sep 26, 2004
#16
  • Sep 26, 2004
  • #16
Headers gaskets Ray, not intake.
5.0Droptop
May 15, 2002
1,785
1,130
233
Indiana
Sep 26, 2004
#17
  • Sep 26, 2004
  • #17
Sorry I didnt get back to you. I have a bad habit of forgetting to subscribe to threads when I post.
A
AJBlackGT
#18
  • Sep 26, 2004
  • #18
Has anyone tried studding their headers? I'm personnaly a fan of studs, its seems they seal better. They're also grat for valve covers.
Gearbanger 101
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Sep 26, 2004
#19
  • Sep 26, 2004
  • #19
It wold be nice, but the only problem is that there isn't enough room to get the headers over the studs within the confines of the engine bay.
LASTFOX
105
RI
Sep 26, 2004
#20
  • Sep 26, 2004
  • #20
MJ, after you install the header gaskets, let the car warm up to normal temp. Then during cool down, tight the bolts, work from the inside to the out. Drive for about 200 miles or so and the tighten one more time after reaching normal operating temp. When the car is completely cool, you can then put the retaining clip and C-clips on the Stage 8 bolts. Thats it.
1 of 2 Next Last
R
bbk shorty header to mid pipe gasket
  • randyyy
  • Sep 29, 2025
1996 - 2004 SN95 Mustang -General/Talk- Sep 29, 2025
randyyy
R
water pump installation questions
  • B0udreaux
  • Feb 5, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 28, 2026
General karthief
Suspension 87 steering wheel slightly wobbles after new Rag joint install
  • R82148V
  • Jun 16, 2025
Fox 5.0 Mustang Tech Jun 24, 2025
R82148V
Engine 5.0 Head Gaskets installed wrong block coolant passages???
  • Xam Sirrah
  • Jul 21, 2025
Fox 5.0 Mustang Tech Dec 22, 2025
Qtrhrse23
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 20, 2026
gray owl
G
