Header Question
  • Thread starter Thread starter mhjo
  • Start date Start date Aug 18, 2014
mhjo
490
Oslo, Norway
Aug 18, 2014
  • Aug 18, 2014
I have the HiPo manifolds right now. I have upgraded engine with roller cam setup, and wonder if I have anything to gain by switching to headers?
And if so, I saw at summit that they have shorty, medium, Tri-Y and full-size. What to go for (if go for)
O
other_shoe
313
  • Aug 29, 2014
I believe there was some testing on the HiPo manifolds vs. Tri-Y finding no appreciable difference. It was discussed in a thread here a couple of years ago.
barnett468
179
24
28
Aug 29, 2014
  • Aug 29, 2014
hello;
what heads do you have?
what intake?
exactly what cam?
what size is your engine?
mhjo
490
Oslo, Norway
Sep 18, 2014
  • Sep 18, 2014
Edelbrock heads
Edelbrock dual plane intake
Comp Cam 31-422-8 (270-HR) Roller
289
Falcon79
214
Dallas, TX
Sep 18, 2014
  • Sep 18, 2014
I like JBA long tubes, good fit even around a large transmission like my AOD. Performance is good but you will have to put them on to see. My setup is similar to yours.
Gt40 heads ported and polished
Ford racing e303 cam
Roller 306
latamud
791
Tampa, FL
Sep 18, 2014
  • Sep 18, 2014
In my opinion, if you want to keep the vintage look then run the Hipo manifolds. I like to run long tubes, Hokker has a set for around $200 last time I checked which was not too much more than a set of Tri-Ys. Shortys or Tri-Ys will keep lower end torque which would be good paired with a dual plane intake. I prefer long tubes, I think they give the best exhaust note.
barnett468
179
24
28
Sep 18, 2014
  • Sep 18, 2014
mhjo said:
Edelbrock heads
289
ok imo, you will not gain enough power to feel with your particular set up. if you are looking for quicker acceleration you can achieve this by installing numerically higher gears.
you should have at least 3.40 gears with your set up otherwise it will be a bit of a slug off the line.
i would also use at least a 2000 rpm stall converter.
you will benefit from an msd 6al-2 box.
if your timing is less than around 12 at idle and around 34 at around 2600 - 2800 rpm with the vacuum advance disconnected, i would try setting it to that.
mhjo
490
Oslo, Norway
Sep 28, 2014
  • Sep 28, 2014
Thankks all. I will stay with the HiPo for now.
Barnett468: Thanks for other advice.
1. I run 3:55 gears
2. I have an extra aod converter (Hughes). Can you explain therpm/stall converter thing?
3. 6AL box; What does one actually gain from the 6AL box?
barnett468
179
24
28
Sep 29, 2014
  • Sep 29, 2014
1. I run 3:55 gears
no prob, you're welcome.
if a stall is 2000 rpm for example, the converter will rev to that rpm before it accelerates if you floor the car. if you taje off nirmally it will accelerate much sooner than that and will be fully engaged sooner. it will also go into "neutral" or disengage at a higher rpm when you let off the gas so you will loose engine braking sooner. look for "tci converter stall" on youtube.com. it helps explain it.
mhjo
490
Oslo, Norway
Sep 30, 2014
#10
  • Sep 30, 2014
  • #10
Thanks. Any thougts on the 6AL?
tx65coupe
Oct 12, 2014
#11
  • Oct 12, 2014
  • #11
I have JBA mid length headers and am very pleased with them. If you switch, consider them. The HiPo manifolds are fine, and I might leave them be.
barnett468
179
24
28
Oct 13, 2014
#12
  • Oct 13, 2014
  • #12
Hello;
Sorry I forgot that, all the 6 boxes increase coil voltage and have multi spark until around 3500 rpm. They are very helpful on some cars but it depends on how they are tuned. The better the tune and smaller the cam the less benefit they are. i would use one on a high perf build just for insurance, I don’t see how one can possibly hurt. You can also run leaner than normal wit one and they can increase hp and tq on some engines. If you do not need a rev limiter just but the plain 6 box for $200.00 from summit.
J
4 bank eliminator chip
  • JJ's90fox
  • Feb 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 17, 2026
AeroCoupe
N
Looking for ECU/CHIP for 1992 5.0
  • Nathan26
  • Sep 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 8, 2026
Qtrhrse23
Stuck
  • bshipley
  • Aug 27, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 28, 2026
squeak93
New Exhaust for 408w stroker
  • SadbutTrue
  • Sep 10, 2026
1965 - 1973 Classic Mustangs -General/Talk- Sep 10, 2026
nickyb
Brake pad and rotor upgrade
  • Sparky714
  • Aug 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2026
Sparky714
