Header Size?
  • Thread starter Thread starter sport200
  • Start date Start date Jan 22, 2015
sport200
73
17
18
LAWRENCEBURG, IN
Jan 22, 2015
  • Jan 22, 2015
How much difference in HP does difference size tubes on headers make. I Know different heads is where u start first but, I'm wondering if to big of tube size could kill HP?
CarMichael Angelo
8,909
234
Birmingham, al
Jan 22, 2015
  • Jan 22, 2015
Yes. A tube too large will slow exhaust port velocity which in turn will affect low end torque. Most headers available for a 5.0 have a tube diameter of 1-5/8", some stockers only measure 1-1/2". Race engine headers can be 1-3/4, 1-7/8, or even 2" in diameter, ( most of which will not even fit a stock port configuration) and every one of them are a sure fire shortcut to eliminate torque in a street car, especially a mildly modified one.
Bottom line: Stay away from the slightly used C/L listed set of Kooks 1-7/8 LT's for a set of R heads.
A5literMan
At least it is lumpy...
5 Year Member
Jul 30, 2011
4,674
2,343
194
Illinois
Jan 22, 2015
  • Jan 22, 2015
^^^ what Mike said. What heads/combo are you looking to do? If stock heads stay with a 1 5/8" shorty(or even keep the stock manifolds). If it's a good h/c/i don't go above 1 3/4(if it's 302-347 based). It all depends on the combination of parts and what you're trying to accomplish.
sport200
73
17
18
LAWRENCEBURG, IN
Jan 22, 2015
  • Jan 22, 2015
Awesome Reply Thanks. I have a set of JBA long tubes on my car with a DART ll cast iron head milled to about 50cc . I was just thinking of going with a different header , these are 15 -17 years old. I cant recall the tube size . Ill have to look it up. Thanks again.
90lxcoupe
20+ Year Stangneter
Oct 7, 2003
3,596
350
134
Jan 22, 2015
  • Jan 22, 2015
This is a blanket statement and not true. You want the correct sized headed for a given application. I had a 1 7/8" header on my old 345" combination that was shifted at 6700rpms, and was fairly mild, there was no noticable torque loss going from a 15/8" to 1 3/4" header to the 1 7/8"
If you are planning on running nitrous you may want to go up one primary size from what the motor wants NA cause you need to get those hot gases out of the chamber as fast as possible, there is not one answer to this question and if you size the header correctly for the combination, you will be headed in the right direction.
Reactions: A5literMan
CarMichael Angelo
8,909
234
Birmingham, al
Jan 22, 2015
  • Jan 22, 2015
It was a blanket statement, because it was a blanket question.
W/O knowing what engine or what the intended use for the op's engine is to be, I doubt that the engine is anything other than stock. And a stock engine will surely suffer from a tube that's too big if its intended use is to be a DD.
Reactions: jozsefsz and 90lxwhite
G
Fox Tire Size for 16" Pony Wheels on 1984 LX Convertible
  • gw7
  • Jun 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 25, 2026
Qtrhrse23
G
S550 Headers
  • gray owl
  • Feb 1, 2026
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Feb 1, 2026
gray owl
G
Engine Keeping O2 sensors lit with long tube headers
  • keel
  • Jul 30, 2026
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
D
Exhaust Difficulty of fixing exhaust leak at manifold
  • dqureshi06
  • Aug 27, 2026
Fox 5.0 Mustang Tech Aug 28, 2026
General karthief
Engine Underdrive pulleys
  • Mindseye007
  • Feb 1, 2026
Fox 5.0 Mustang Tech Feb 14, 2026
Willybill32
