header wrap question
  • Thread starter Thread starter snoboardcore
  • Start date Start date Jun 26, 2005
snoboardcore
276
New Hampshire
Jun 26, 2005
  • Jun 26, 2005
hey guys in the engine bay is really hot from the headers. I was thinking about wrapping them but first i wanted to know if it really works and how well does it work thanks
maverick0716
3,924
Chilliwack, BC, Canada
Jun 26, 2005
  • Jun 26, 2005
Yes, I know that it works.....and it looks kinda cool too. I've heard bad things about it though.....like it'll rust your headers prematurely and stuff like that because it holds moisture in.
stang8urimport
Autozone Junkie
1,499
12
59
Daytona Beach, FL
Jun 26, 2005
  • Jun 26, 2005
What he said. They work, yes. But they will make your headers rust from holding in moisture, and header wrap voids all header manufactures warranty
vikingpower
656
CWU Ellensburg, WA
Jun 26, 2005
  • Jun 26, 2005
they get too hot and warp/crack when you wrap them. not a good idea!
C
criticman
723
Rome, GA
Jun 26, 2005
  • Jun 26, 2005
Just get the headers Jet Hot coated and be done with it. Keep the heat in, don't produce sitting moisture, and look good too.
Vipersix
434
Clarksville, TN
Jun 26, 2005
  • Jun 26, 2005
Two words: Jet Hot!! Never go without them on a true performance car.
snoboardcore
276
New Hampshire
Jun 26, 2005
  • Jun 26, 2005
where would i get the headers jet hot coated or where can i buy it to do it
stang8urimport
Autozone Junkie
1,499
12
59
Daytona Beach, FL
Jun 26, 2005
  • Jun 26, 2005
It's not something you do yourself. You'd have to send them to Jet Hot themselves to do it, or have a local place that does ceramic coating/powder coating.
larrendeuce
649
Southern NJ
Jun 26, 2005
  • Jun 26, 2005
How would the stock headers hold up with header wrap? They don't rust out even after a couple hundred thousand miles since they are 409 stainless. They get surface rust and look nasty but they stay whole.
Vipersix
434
Clarksville, TN
Jun 26, 2005
#10
  • Jun 26, 2005
  • #10
Most places that coat headers only do the outside so be very careful who you go to for this. Jet Hot coats the inside and the outside so you won't have the rust problems you do with others.
Wrapping headers with the cloth or tape will significantly reduce underhood temperatures, however, the extreme heat will generally burn the carbon from the tubing and extensive radial cracking will occur. Not to mention all kinds of rust. Typically you can expect a 2% to 3% loss in hp from the rust that forms overnight in a new set of headers. Compound that over the 100k miles you probably will want to put on them and you'll be buying new headers in no time.
notchback
1,950
St Clair Shores MI
Jun 26, 2005
#11
  • Jun 26, 2005
  • #11
they hold the heat in and don't let it cool off, not a good idea on a street car...race only is good to go though
K
Engine Gt40p vs 180 procomp
  • Kleinjj27
  • Oct 27, 2026
Fox 5.0 Mustang Tech Nov 3, 2026
Kleinjj27
K
Engine (EGR Deleted) Solution the hotter combustion chambers?
  • PonyGTrider
  • Jan 21, 2026
  • 3 4 5
4K
Fox 5.0 Mustang Tech May 2, 2026
PonyGTrider
Electrical/engine bay harness questions
  • djj62478
  • May 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 6, 2026
djj62478
Turbo header Starter wire routing?
  • 387lx
  • Mar 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 3, 2026
387lx
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
