Howdy folks, I have a 289 A code 65 gt convertible- starts well enough when it's cold.
When it has been driven for a bit, and I turn it off to go into a store for 5 minutes, then come out to fire it up, it's... angry.
It turns the starter- barely. If I wait 30 minutes, it fires up like normal.
I'm 95% sure it's because of the Tri-Y headers- they run RIGHT next to the starter (.5 inches)
Now, what does the populous do about this? Do I just have a worn out starter? Is the heat always going to be a problem? There are thousands of Tri-Y's installed- how do people deal with this?
Also, I've heard that rebuilt ford starters are questionable- how is your experience with getting it rebuilt by a local starter/alt shop? (never done that. D/FW suggestions?)
Thanks!
Thanks!
You described my symptoms exactly. I purchased a DEI Versa shield ( it's a blanket or wrap) but have not installed it yet. I was also given a heat shield that is metallic looking. I did install that and it seemed to help a little. I'm hoping the versa shield will add just what is needed. I was also thinking that my alternator was not charging my battery enough but after reading your post I'm pretty sure we have the same problem.
