  • 1994 - 1995 Specific Tech
Headlight problem 95 GTs
  • Thread starter Thread starter vip3r
  • Start date Start date Oct 21, 2004
V
vip3r
  • Oct 21, 2004
The headlights on my mustang GTs, after it gets hot inside the engine compartment, will start to flash on and off, its only the headlights and none of the other lights. It makes the car almost impossible to drive at night when this happens. Someone stoped to help me out last night and said it is a headlight relay that went bad, but I cant seem to find any info on headlight relays on the web or for that matter any problem similar to this one. Im kind of desperate for the help cause were getting ready to move and were going to need to drive the car at night. we really hadnt noticed the problem before but thats probably cause Ive only had the car for 4 months and havent had to drive at night much.
Thanks for the help,
Vip3r
M
Marks01L
30
  • Oct 21, 2004
Replace the head light switch in the dash. There is a circuit breaker in it that will go to hell with age. Good luck!!! Mark
V
vip3r
  • Oct 21, 2004
Thanks very much mark, ill try to do that tomorrow. BTw how difficult is it? anyone have directions on how to do something like that?
V
vip3r
  • Oct 22, 2004
ok im working on this, but how do I get this head light knob off, I did a google search and it found an old post thats been deleted, that had directions but its gone now any help would be awesome.
Thanks,
Vip3r
Edit: I got it off, thanks, need to find a harness connector ours is melted, so thats looks like it was the problem
lager94GT
119
LI, NY
Oct 22, 2004
  • Oct 22, 2004
Do a search for install tips on mustangworld.com. They installed whiteface gauges and in instructions they describe how to remove the switch.
I think it was similar to this...
Get a nail and make a 90 degree bend at the pointed tip leaving approx. 1/4 as a "poker." There's a small slot/channel on the headlight switch that runs parallel with the length of the switch. Slide the nail in the channel towards you and and pull on the switch.
V
vip3r
  • Oct 23, 2004
thats almost exactly what I did, thanks very much. The headlights seem to be working with the new switch, with out a problem so far.
Electrical Headlight harness trouble
  • 1985fox
  • Apr 14, 2026
Fox 5.0 Mustang Tech Apr 17, 2026
AeroCoupe
D
Mustang not starting
  • Dawry Ramos
  • Sep 12, 2026
  • 2015 - 2023 Specific Tech
2015 - 2023 Specific Tech Oct 3, 2026
Dawry Ramos
D
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
P
Electrical 1988 GT Wrong Cluster- causing electrical issues?
  • pindude80
  • May 6, 2025
Fox 5.0 Mustang Tech May 6, 2025
pindude80
P
9
Resolved HELP! - 1992 5.0 Canadian with DRL - need electrical schematic drawing
  • 92StangGirl
  • Nov 28, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 7, 2024
92StangGirl
9
