  • 1994 - 1995 Specific Tech
Headlight Switch....Plz Read!
  • Thread starter Thread starter KarmaKid
  • Start date Start date May 5, 2005
K
KarmaKid
84
Western MA
May 5, 2005
  • May 5, 2005
Hey guys,
Replacing headlight switch. Removed the knob and bezel and switch from dash no prob.
I am trying to remove the shaft that the knob sits on from the defective switch to put it on the new one??
I'm wondering if the shaft is supposed to already be on the new one??
Thank You,
Jer
(2 minutes later) Update: LMAOL.....pressed the lil button on the switch and it slid right out.......what a tard.
MLC Stang
210
Atlanta, GA
Oct 31, 2005
  • Oct 31, 2005
Karmakid,
Really late reply, but I just did this job this weekend and it drove me nuts, but I figured it out. Hopefully it will help someone out.
You have to reuse the shaft that is in the old headlight switch. To get it out you have to first remove the two-legged bracket from the old switch by unscrewing the big nut on the front.
Once the bracket is off, you then need to tilt the shaft to the side with your thumb before you pull up on the shaft. The trick is to find which side to tilt the shaft toward. You only have four choices so just try all four directions and you will get to the side that releases the shaft.
Basically, the shaft is held inside the switch in an oblong hole in a piece of metal that a slot in the end of the shaft slides into sideways. So, you have to tilt the shaft sideways before you pull up to get the tip of the shaft out of that slotted hole.
I verified that this is how the shaft is held inside the switch by completely disassembling the old switch until I had all of the insides removed.
If you still can’t get the shaft out, just drill out the three pop-rivets that hold the large metal bracket onto the side of the switch. That will allow the entire switch to be taken apart. Once inside you can easily remove the shaft.
Electrical 1985 mustang gt Led conversion trouble
  • 1985fox
  • Jan 5, 2026
Fox 5.0 Mustang Tech Jan 15, 2026
1985fox
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
Crank no start, I’m stumped!
  • Seth Brogan
  • May 18, 2025
1996 - 2004 SN95 Mustang -General/Talk- May 14, 2026
BossHorseGirl
Fox New to me 82 GT
  • Stangman7082
  • Jan 20, 2025
  • 2 3
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 18, 2025
AeroCoupe
D
Double check my electrical diagnosis of light issues on 65 Coupe
  • Duke City Novice
  • Jan 21, 2024
1965 - 1973 Classic Mustangs -General/Talk- Feb 4, 2024
AeroCoupe
