headlights and foglight setup?!?!
  • Thread starter Thread starter FoxFiveO88
  • Start date Start date Nov 17, 2008
FoxFiveO88
  • Nov 17, 2008
my lights flicker when i keep my fogs on for a certain amount of time....i know this is a common problem of the wires overheating.....how can i fix that and i want to wire it up to where i can have my markers and fogs on at the same time...can anybody tell me how....??? thanks!!
HISSIN50
34
129
Nov 17, 2008
  • Nov 17, 2008
Mustang GT Fog Light Fix
If that article doesnt mention it, to have the fog lights operational when the marker lights are on, you change the fog light switch's feed to the parking light wire on the headlight switch (a brown wire IIRC).
I would use a 1-3 amp fuse on this wire you add and tap into the parking light circuit (a 30 amp SPST/SPDT relay-coil generally draws under one amp).
Good luck.
FoxFiveO88
  • Nov 17, 2008
will this fix the cause of using my brights and my headlights start flickering after overheating?
FoxFiveO88
  • Nov 17, 2008
thanks alot hissin!!!!!!
Saleen8786
209
Marlton, NJ
Nov 17, 2008
  • Nov 17, 2008
yup it'll fix the flickering problem!
dp88
40
  • Nov 17, 2008
I tried to tap into the parking lights to give the fogs power but there are 3 brown wires, well 2 brown 1 brown/white. from what i understand the blue/black wire from the fogs need to go to a brown but where does the other fog wire tap into? a ground. sorry im probably way off track.
FoxFiveO88
  • Nov 17, 2008
good question...lol..anyone?
HISSIN50
34
129
Nov 18, 2008
  • Nov 18, 2008
There might be two parking light feeds leaving the switch (going different directions eventually). You always check any wire you're going to tap into with a DMM or at least a test light. The correct wire will become hot when the parking lights are selected (even if the dimmer is turned off) and stay hot while the headlights are also on.
On the foglight switch, one wire will go to the parking lights, functioning as the new power source for the switch (as noted above).
The other leg will now be going to the relay-coil on the relay you're adding.
dp88
40
  • Nov 18, 2008
Must you add a new relay my lights dont flicker or any of that mentioned above. i guess they probably will but i dont really want to go out and buy a relay, wires, crimp conectors, ect.
HISSIN50
34
129
Nov 18, 2008
#10
  • Nov 18, 2008
  • #10
If you never use your fog lights, then there's no real point to doing it.
There isn't an old relay - there's none at all.
If you want to save aggravation in the future (after the circuit overheats), it would be wise to do this now (since it will end up being done anyhow).
I would see if you have a friend who enjoys doing electrical installs (since you don't have supplies, we might assume you don't). The repair will probably be easier and more robust that way. And be sure to solder the connections for longevity.
Good luck.
dp88
40
#11
  • Nov 18, 2008
  • #11
yeah im not big into electrical things i got tired a fixing things like this in my old prelude. I do use my foglights everyday though so that was the reason i was wanting to control them separately. Thanks for the help you always seem to know what your talking about.
Electrical Headlight harness trouble
  • 1985fox
  • Apr 14, 2026
Fox 5.0 Mustang Tech Apr 17, 2026
AeroCoupe
Electrical Ron Francis Headlight / Alternator Harness
  • dan50
  • Apr 30, 2026
Fox 5.0 Mustang Tech Apr 30, 2026
dan50
Electrical Code 29 again
  • Creomod
  • Jul 31, 2026
Fox 5.0 Mustang Tech Aug 3, 2026
Creomod
  • Mindseye007
  • Aug 16, 2026
Mindseye007
2010 V6 Sees differently than GT?
  • 6t9Mach1
  • Mar 31, 2026
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech Apr 1, 2026
6t9Mach1
