OK I took my car completely apart well the interior I figure I'll start with the headliner and work my way down.
Problem 1 : the front came down easy! the sides came down easy!, but the rear is under a piece of rubber (that I can't remove, I think its what the window sits on) I tore it to get the whole thing out but some of the headliner fabric is still under there and when I fold the rubber away to gain access and let it go it turns brown I'll try to clean it next.
?2? will I be able to just tuck the new headliner in at the back I'm scared that when the wind its it it'll come out?
Next ?3? there is a pad up there its a lt brown almost yellow looks like fiberglass matt like in your walls but only about 1/2" thick.
Will this do or do I need more?
I was heavy into car audio (an Installer) and I have about 4 tubes of Punch matt its close to the same as Dynomatt I was thinking of putting that in the car I don't have enough to do the whole car but maybe the right size pieces in the right places will do as well as getting more of the thick stuff they sent to go under my trunk mat.
?4?I'm going to order the parts from Tony D. Branda please correct me if I should go somewhere else he has the headliner for 34.95 I will also be getting the glue and be asking about a roll of the padding and a set of the rods for the sunvisor (mine look too old)
?5?the pinch molding on my car is in tact but was coming down a bit where the window curves I guess if I roll it back it will stay but its real sticky what should I try to clean it with. before painting?
?6? what interior paint are you guys using I got some flat black from Pep boys and it sprays terrible splatters every ware and is watery
Please comment! bnickel I know you have something!
