Here is what I have:
Stock block with 89k.
Everything is apart and I am ready to put back together, here are the parts I have:
AFR Aluminum heads
FMS 1.6 RRs
FMS B-303 Cam
FMS pushrods and lifters
FMS dual-roller timing chain
FMS 30lb injectors
GT-40 Aluminum intake
Not a novice, just looking or some refresher points....
With the engine at TDC should the new cam slip right in with the lifters and pushrods removed?
I should be able to drop the new lifters/pushrods in and bolt the new timing chain on with no problem as long as I keep the engine at TDC correct?
Aluminum heads torqued how much different than stock?
Adjusting the rockers( heads are complete minus the FMS rockers), any help there?
Everything else I will install new, Ex: distributor, water-pump, gaskets, etc....
AFR Aluminum heads
FMS 1.6 RRs
FMS B-303 Cam
FMS 30lb injectors
