Heads For Perfomer Intake
  • Thread starter Thread starter southjersey5.0
  • Start date Start date Apr 6, 2014
southjersey5.0
  • Apr 6, 2014
hello, new to the forum. was wondering what heads would work best for stock cam and edelbrock perfomer upper/lower as well as all the basic bolt ons. shes a street and occasional track
gearheadboy
1,425
177
84
Greencastle Pa
Apr 7, 2014
  • Apr 7, 2014
If you have the heads off, you are a few bolts from the cam. Or 1.7 rockers on the stock cam to help get the thing to work with your intake. As far as heads I like AFR 165's but they cost the same as anything else. Good moderate street/strip head. Pick what you want but match the whole set-up. Work around the intake since you have it and it will work well for your needs?
A5literMan
At least it is lumpy...
5 Year Member
Jul 30, 2011
4,674
2,343
194
Illinois
Apr 7, 2014
  • Apr 7, 2014
Afr 165,tfs 170-190cc,gt40's any of these will work/flow better than the performer intake. I like trick flows the best. And I def would upgrade the cam if I already was throwing on aftermarket heads/intake. It's all about the combination of parts. You don't have to go crazy with the cam profile though. A good everyday performance off the shelf cam would be tfs1,comp cam 264,etc. a custom cam from somebody like FlowTech Inductions,Etc is ideal.
Reactions: Sfv50h
mikestang63
SN Certified Technician
Aug 27, 2012
11,606
8,859
214
In the garage
Apr 7, 2014
  • Apr 7, 2014
what are your goals
stick or automatic
what is your budget
what gears in the rear
That being said, a tried and true combo is this
TW 170 heads
lsx springs from FTI
Tom Moss ported exlorer lower
FTI cam
easy 300-330 rwhp with the appropriate MAF, TB, injectors, exhaust
Reactions: Sfv50h
Sfv50h
California
Apr 7, 2014
  • Apr 7, 2014
I havea 88 5.0 wanted to upgrade my heads thinking afi or trickflow 165 its an aod with 373 gears. thinking of getting a custom cam and victor x manifold but i wana go forced induction on it in te future...i dont wana buy head twice..should i get the 185 afi or stick with 165cc any help and info will be great thanks
A5literMan
5 Year Member
Jul 30, 2011
4,674
2,343
194
Illinois
Apr 8, 2014
  • Apr 8, 2014
A lot of people like the tfs topend kit. FYI the valve angle on tfs heads give a little more ptv clearance So you can run a little more cam than with Afr heads. What kind of forced induction? Turbo? Blower? Afr 185 heads have some ptv clearance issues over the tfs heads. I really really like the new tfs 11r 190cc heads. They come with top of the line PAC springs,bigger valves,locks&retainers,etc. Your ultimate goals should determine what head you go with. If you truly plan on making a lot of hp go with the bigger head(185-205cc). If it's going to always be more street than race you can go with the smaller cc alum heads. Just remember the entire package has to be designed to work together. Mismatched parts can make an under performing car.
Reactions: Sfv50h, 89oem and mikestang63
84Ttop
5 Year Member
Jul 2, 2009
5,222
3,255
204
South Jersey
Apr 8, 2014
  • Apr 8, 2014
Welcome to STANGNET!! Where are you located in South Jersey?
Sfv50h
California
Apr 8, 2014
  • Apr 8, 2014
custom cams are a bit away from my price range so thinking of a x or f cam and not sure im trying to stay away from a lot of fab work so maybe the on3 turbo kit or a used paxton not trying to yank tire but hold my own on the street i drive the car maybe once a week if im lucky ...my friend said 165 cc are good for under 500hp...But the power adder wont be going in any time soon. so i wanted something i can use for both applications
D
N/A build on fresh stock 302
  • djcarrot
  • Oct 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 19, 2026
AeroCoupe
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
J
Intake
  • James S
  • Jul 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 12, 2026
James S
J
T
Rpm vs rpm2
  • thor347
  • Mar 17, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 19, 2025
thor347
T
G
Sup. Just got back into the game with a 1986 4-eye vert.
  • GeorgeG
  • Nov 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 7, 2026
limp
