heads intake and cam?
alludethis
58
Got the engine torn down and ready to pull. Im looking at doing my hci combo but am confused by ALL the choices out there. I would love 400 HP. Would GT40 heads, ported intake and an alphabet cam maybe B, along with exhaust get me close. What size TB should i use and roller rockers etc. I basically need someone to really help me decide what to use. I'm new to this stuff but am desperate to learn, and definetly dont want to have to pay for it. The car has 170K on it and while im in there im thinking about redoing the pistons, rings and rods a crankshaft, is that stuff i can do myself, or does it have to be a machine shop? If anyone can help me out it would be GREAT!
gt40 heads, a ported intake, and a cam will get you NO WHERE close to 400hp... it would be more like 245-265 HP (if ur lucky).
In fact, getting 400 hp out of a N/A 302 will be very difficult with any H/C/I combo. In order to do it N/A you really need more cubes and bumped compression.
However, a very mild H/C/I and some BOOST will net you 400hp fairly easily. However, with a 170k engine, I wouldnt reccommend that.
Dude, you're going to have to pull the engine and strip it completly and start from there. You are going to HAVE to do the following if you want a healthy engine.
1. hot tank block & probably bore it at least .030 & have deck check
2. Have crank journals check and probably turned & polished
3. new cam bearings(which is automatic when hot tanked)
4. check align bore
5. rods magnafluxed & resized if buying new bolts(recommended)
I know I missed some things that should still be done but that's the basics.
Have a GOOD machine shop do that for you and by then you'll have about $400 in it.
If you insist on keeping the 302 and not go bigger and still looking for 400hp then I would buy a stroker kit and build a 331 or 347
When you decide which way you want to go(302 or 351) and get your machine work finished come back and we'll talk heads/cam /intake
your probably want to keep it streetable so I recommend boost. Since you are already getting the bottom end rebuilt, a 331 stroker sounds good. A nice set of aluminum heads, a matching cam (maybe even an anderson boost cam) and a small blower. You can get over 400 and be streetable.
It would be a lot cheaper to buy nitrous. You could build the 302 for about 300hp and then add 100-150 shot of nitrous for the rest of the HP
There's pros and cons for both blowers and nitrous. You would have to decide for yourself which is best for you.
Thats right
My combo consists of ported and honed cobra intake gt40p heads with 1.6 rollors, crane cams cam (not sure what size) all bolt on's elec fan long tubes 24# injestors. I put down 301 H.P and 328 TQ at the wheels Like they said you only got a little 302 cubic inch engine not no 350 cubic in like those chevy guy's. Now if ya want 400+ at the wheels go with a 351! peace
john:p
A better question would be: How much money do you have to spend?
That, and only that, will dictate how much HP you end up with.
If you want a 400hp 302...it's gonna cost ya some bucks and a stroker kit is must.
Ive actually just purchased through my g/fs grandpa another 5.0 engine. I havent seen it yet, but Im sure its in great shape. I'm going to probably go ported GT40s and maybe a different intake or a ported stock one. We're definetly going to go boost. Easier HP and I have experience in boost.
Make sure the 5.0 motor is a roller motor. If you have an extra motor, seriously take the motor to a machine shop, and then build a 347. Holley intake, afr 185's, and a custom cam should get you to 400hp if not very close. And then you can just add some juice, or if you want to boost youll be making more power then you know what to do with. But like said you wont get very far at all with iron heads. But if you are for sure boosting, id say go typhoon intake, gt40p heads, and a fcam, add the s/c and hope it dosent blow.
do you want your car to be streetable? or is it a track car?
EDIT: nevermind, i just saw your post. Since your using those gt40's, I would do a 306, anderson blower cam with 1.7's, all the bolt ons, and a s-trim. That should put you where you want it.
