heads
  • Thread starter Thread starter DMBcentral
  • Start date Start date Oct 5, 2005
DMBcentral
10
10mi west of Indianapolis
Oct 5, 2005
  • Oct 5, 2005
Ive been doing some research on diff heads. I am going to do a budget rebuild this winter, with stock bottom end except new 30 over pistons. Since it is going to be budget the heads are not going to be new. So I did some searching and found that 351W prior to 74? are good, 289 hi-po heads, or E7's ported by Thumper? Wich would be the best for the job. Also what size valves would work best? No matter which I get they will be ported with hardend valve seats put in and cleaned up. Also I was going to go with 10:1 -10.5:1 comp. The motor will be carb. with a holley 650 and a dual plane intake. This motor will see alot of street driving and some track, So I want somthing with good low end torque, but sill wind out good top end. Thanks all
Lyncher
434
  • Oct 5, 2005
I have no first hand experience but have heard excellent things about thumper e7s hopefully that helped a little
thumper460
3,022
Orange Park , Fl
Oct 9, 2005
  • Oct 9, 2005
Ford uses the stock E7 heads with the smaller 302 valve size on the W engines !! for the street and a few blasts down the strip.. the stock valve size in the E7s will allow KILLER high velocity and make the W rip trees out of the ground.. and still power to 6K if you want to go there... larger valves ( say 1.85/1.55 ) will increase the top end power and flow and still maintain almost the same low end grunt!! You will need the 302/5.0 heads drilled out for the larger W head bolts... and then they are a bolt on mod!!!!
Just me............................
Thumper
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
A
Discussion on mild budget build/ top end
  • Acesario
  • Feb 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 23, 2026
General karthief
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
2K
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
9
Will I feel a difference
  • 90Stanger302
  • Mar 12, 2026
1965 - 1973 Classic Mustangs -General/Talk- Apr 13, 2026
Running very very rich
  • 2esoteric
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
