  • SN95 4.6L Mustang Tech
Heads?
  • Thread starter Thread starter Alex46
  • Start date Start date Mar 12, 2010
Alex46
50
  • Mar 12, 2010
I have done everything on the engine but these. Want to change it to a 4 valve so i can get a lot more power but also heard about some new heads trickflow was coming out with a few months ago that people were raving about. What are the best in your opinion?
Regards,
Alex
mogs01gt
3,113
30
119
Ohio
Mar 12, 2010
  • Mar 12, 2010
In a price comparison, the trickflow heads + cams will give you more power for cheaper. Porting the 4vs and upgrading the cams will run you a lot of money.
Get the trickflow.
Alex46
50
  • Mar 12, 2010
Appreciate it. Yeah i wasn't go to do the 4 valve swap unless i found some package deal, it's just way too much. Were those new trickflows over hyped or is the air flow as impressive as they were saying?
Edit: What are the new Trick Flows called? The 185 series?
bboylobo
130
Lancaster PA
Mar 12, 2010
  • Mar 12, 2010
wouldnt you have to drill your block to coonvert to a 4v?
Alex46
50
  • Mar 12, 2010
From what i understand you just have to change the timing chain. A friend did it. But there's a compression issue i wasn't thinking about. When you go to the 4v your going to have lower compression but still a 40 horse gain. But hearing you can get that with these Trick Flows (with upgraded intake, TB, Mass Air, Headers, exhaust
mogs01gt
3,113
30
119
Ohio
Mar 12, 2010
  • Mar 12, 2010
No, you have to drill a 4v block for 2v heads.
The Trickflows arent hyped.
Winters98GT
Whoop...whoop-whoop-whoop-whoop...GANGNAM STYLE!!!
1,291
224
H Town
Mar 12, 2010
  • Mar 12, 2010
There is more to putting 4v heads on a PI block than just the timing chain. If you can afford the Trickflow, I would look at those.
Alex46
50
  • Mar 12, 2010
Think i am going to go with the Trick Flows. But what series are these new ones? Went to there site and they only have one pair. Guess that's it. Seemed to rember though that they didn't offer any for the 2v, but it's been a few years
Tim2002GT
635
Tulsa, Oklahoma
Mar 12, 2010
  • Mar 12, 2010
They offer 2 different heads for 4.6's. The combustion chamber sizes is the difference. You will want the smaller chamber heads. They will also give you a slight bump in compression over your PI heads.
Alex46
50
#10
  • Mar 12, 2010
  • #10
Thanks Tim. Why do i need to go with the smaller one's? Everything in my intake to exhaust is upgraded. Or does it have to do with something else?
Winters98GT
1,291
224
H Town
Mar 12, 2010
#11
  • Mar 12, 2010
  • #11
Compression.
N
ninjastang125
591
maryland
Mar 12, 2010
#12
  • Mar 12, 2010
  • #12
The smaller chamber will bump your compression, which will compliment all of your bolt ons. The smaller chamber is for npi cars, they are the same chamber size as a stock p.I head. The heads your are looking for are the twisted wedge 38 cc chamber.
Tim2002GT
635
Tulsa, Oklahoma
Mar 12, 2010
#13
  • Mar 12, 2010
  • #13
You actually have it backwards. The smaller chamber heads are designed for the PI cars. They have a deeper dish in the pistons stock than NPI cars do.
Alex46
50
#14
  • Mar 12, 2010
  • #14
PI Power Induced? Plan on putting a Kenne Belle on it, but not until next year. Wanted to get in high 11's NA with stock block and Crankshaft, but I don't think i can with this DD
Winters98GT
1,291
224
H Town
Mar 13, 2010
#15
  • Mar 13, 2010
  • #15
No, it's "power improved".
You really need to plan on what you want to do with your car.
The 2v Crank is good for 500-700hp. You don't need to mess with a Cobra Crankshaft. The stock block is good for over 400rwhp.
If you want to go 11's on the stock block, it can be done and be a daily driver.
If you have not done headers/gears, then I would start with that. Then, go with a power adder. The Kenne Belle Blower should have you knocking on the door of 11's with a nice 60ft. I am sure Tim, and other Nitrous guys can point you in the direction if go that route. Eitherway, I would leave the PI heads and Longblock(maybe cams) alone. If your goal is 11's on the stock block with a power adder, you are going to be spending a lot of money on heads/install/tune right now if you decide to tear the motor apart and go with Trickflow heads. Factor in the labor if you are not doing the work. I would save the money for the blower.
N
ninjastang125
591
maryland
Mar 13, 2010
#16
  • Mar 13, 2010
  • #16
Yea tim I did get it backwords I got to far ahead of myself. The larger chamber is for npi and the smaller is for pi. This guy wants to go 11s on motor then put a kb on. Good god.
R
rconaway
1,415
Phoenix, Az.
Mar 13, 2010
#17
  • Mar 13, 2010
  • #17
I did ported Livernois heads with their stage 1 cams. Check the Sig andsee if thats enough power and we aren't even close to finished yet. We expect 700+. If I upgrade the blower to an SI, then expect 750 or better.
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
D
Electrical Weird door wiring issues
  • Dakar09
  • Tuesday at 8:54 AM
Fox 5.0 Mustang Tech Wednesday at 8:21 PM
Dakar09
D
J
'04 3.8L V6 mineral deposits and oil on #3 cylinder. Does it need a rebuild or something simpler?
  • joeybuddy96
  • Mar 18, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 29, 2026
gkomo
4.6 spitting o-rings out of 2 injectors
  • skidad
  • Sep 30, 2026
  • 2 3 4
1996 - 2004 SN95 Mustang -General/Talk- Oct 15, 2026
skidad
  • Gulftown980x
  • Jul 29, 2026
squeak93
