  • SN95 4.6L Mustang Tech
Headswap gone bad?
  • Thread starter Thread starter Blev
  • Start date Start date Dec 20, 2004
Blev
1,295
So. Cal. V-Town
Dec 20, 2004
  • Dec 20, 2004
Here is the problem. I torqued the heads down without putting the cams (cam sprockets) in the correct location. If I take the crank to 9 'oclock (all pistons below deck) can I turn the cams to get them into the correct position? What can I do to fix this.
Someone kick me for not paying attention.
tomustang
Psychotic Member
3,434
McLean Hospital
Dec 20, 2004
  • Dec 20, 2004
there is a marker left of TDC on the timing chain cover, i think it's 15 degrees TDC. it's suppose to be safe mode where you can move the cams.
billyfe390
573
  • Dec 20, 2004
Make your life easier.
Take the rockers out because you will never hold the cams at the right spot to get the chains on with them in.
tomustang
Psychotic Member
3,434
McLean Hospital
Dec 20, 2004
  • Dec 20, 2004
oops, i gotta stop posting when i wake up, take the rockers out.
Blev
1,295
So. Cal. V-Town
Dec 20, 2004
  • Dec 20, 2004
didn't have to take anything off. I just set the pistons below TDC (9:00) and cranked them over from the crank bolt using a breaker bar. Was easy as can be. Then just had to slightly move them to get the links to lind up with the dimples on the cam sprocket. Should have it finished tomorrow.
TweekedGT
1,274
Alberta
Dec 21, 2004
  • Dec 21, 2004
Sounds like you know what you're doing. Tell us what you think once you get them installed. I think you will be pretty happy with the result.
Timing chain, guides and tensioner installation (Possible orientation in Intake Stroke)
  • StallionMax
  • Sep 21, 2025
SN95 4.6L Mustang Tech Sep 24, 2025
StallionMax
Fox won't crank over and fuel pump won't kick on.
  • djj62478
  • Jun 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 11, 2026
General karthief
My next project , a 428 build!
  • horse sence
  • Jul 29, 2026
  • 4 5 6
2K
Classic Mustang Specific Tech Today at 6:10 AM
DadLife0724
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
Hard to start when engine is cold
  • 86_Capri
  • Mar 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
