heat
  • Thread starter Thread starter spyder22
  • Start date Start date Feb 8, 2007
spyder22
  • Feb 8, 2007
ok i dont know what is wrong but maybe one of you do...i change the water pump radiator thermostat and the heater core and i still have no heat at all can anyone give me a heads up at all ?
nonglossjason
I did not have intercourse with a sheep.
Jan 27, 2006
138
20
39
Feb 8, 2007
  • Feb 8, 2007
could it be your guage, i dont understand what you are asking?
spyder22
  • Feb 10, 2007
i am asking y dont i have heat still i changed everything that has to do with my heat and i still get cold air out the vents and half the time it wont come out of the vents it comes out the defrost on the winshied ...
Foxbody1993
55
  • Feb 10, 2007
Im having the same problem. I have been looking for a vaccum leak. Still have not found any. If you figure it out before I do will you please PM me? Im working on mine right now. If I find the problem I will post it and PM you.
BK_CAULEY
it's built for speed not longevity, woman
Dec 26, 2006
49
Thomasville, ga
Feb 10, 2007
  • Feb 10, 2007
here is a link
http://forums.stangnet.com/showthread.php?t=680378
you can see the little line i have circled in red in my attachment on my post. this line runs into the fender well to a vacum reservoir. this was broke on mine and was what was causing it to only comer out of the defrost. and as far as having no heat, if you lay on your driverside floor and look behind the haet/ac comtrol panel you can see a little vacum controlled module and there is a (on mine a yellow line) running into it. i will try to get yall a pic of it. but that came un-done on mine during the swap and when i hooked it back up i had heat again. let me know if i can help anymore.
Foxbody1993
55
  • Feb 10, 2007
BK_CAULEY
In the pic you posted, Mine has all of those lines attached. One goes into the fender well, one into the firewall and one into the wrap of wires and stuff. HOWEVER I check my vac dist. block and the A/C vancum line in broken. will this cause this?
EDIT : Just looked at the diagram on your thread and THATS THE PROBLEM!! Well for the defrost anyway.
vikingpower
656
CWU Ellensburg, WA
Feb 10, 2007
  • Feb 10, 2007
I noticed the same vacuum line disconnected on mine yesterday, but didnt know what it was for... I've been wondering why only the defroster heat works!
BK_CAULEY
Dec 26, 2006
49
Thomasville, ga
Feb 10, 2007
  • Feb 10, 2007
glad i could help
yea i figured that was what was cauing yalls defrost problem. i will try to get some pics of that vacum module under the dash tommorrow. it is what lets the hot air in. im pretty sure that will fix your problems.
Foxbody1993
55
  • Feb 10, 2007
Thank god I have been freezing my ass off!! My heat gets warm but not hot enough to warm the car much.
spyder22
#10
  • Feb 10, 2007
  • #10
thanks for the replys guys..and if i fig it out before you i will let you know ok ...and i do have some broken lines that went to my a/c and the box where my evap core is,is open could any of them be causin the problem ?
Engine Bleeding air in the heater core
  • keel
  • Apr 2, 2026
Fox 5.0 Mustang Tech Apr 23, 2026
limp
Engine Themostat
  • Mindseye007
  • Jan 30, 2026
Fox 5.0 Mustang Tech Feb 1, 2026
86HO5.0
Engine New factory manifold no start
  • Fishnchips
  • Oct 15, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Oct 22, 2026
DadLife0724
Engine 1986 GT Overheating issues
  • 86 5O GT
  • Jan 25, 2026
Fox 5.0 Mustang Tech Jan 29, 2026
86 5O GT
K
86 GT Water Pump
  • Kade5114
  • May 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 11, 2026
nickyb
