Heater control cables
  • Thread starter Thread starter mschmidt10k
  • Start date Start date Jun 13, 2004
mschmidt10k
34
  • Jun 13, 2004
I'm having the hardest time getting those 3 pesky heater control cables hooked back up - so that they actually slide around correctly.
Is there a trick to this? Does anybody have a photo that can show me how they're supposed to be attached to the heater core/plenum?
Thanks!
NorCal66
334
Virginia Tech, Blacksburg, VA HOME
Jun 13, 2004
  • Jun 13, 2004
I know it's a fairly obvious pointer, but you may want to make sure you have the knobs on the control panel down (errr it's been a while, which ever makes the wires longer). Shouldn't be too much of a problem
mschmidt10k
34
  • Jun 13, 2004
Yeah, I've done that - what I'm confused about is how far in the cables need to be connected to the little posts. Check the picture below - it's those two marked areas I'm confused about. I've attached the cables there, but they don't seem to slide back & forth properly ..
T
torrie68
  • Jun 13, 2004
are you the guy from the dallas cowboy forum?
mschmidt10k
34
  • Jun 13, 2004
Nope.
mschmidt10k
34
  • Jun 13, 2004
Well, after an hour of experimenting, I finally got them in place - was a hassle to get them to line up, but at least they slide nicely now. On to the next project
NorCal66
334
Jun 13, 2004
  • Jun 13, 2004
What do you mean exactly by slide back and forth properly. If they're just stiff then use some WD40. Any other problem can only be on the control panel, the wires and the levers on the heaterbox and plenum themselves are pretty simple, not much can go wrong there.
Edit: nvm, I posted right after you did, glad you got it figured out
M
mike_o
  • Jul 20, 2006
Thanks!
I have almost the same problem that you had on my 67, I hope you can help me with mine. I´m trying to install the heater and defroster cables. But I´ve forgot which way under the dash they go, I´ve big problems to get the right lenght of the cables from the heater/defroster to the controls left of the steering wheel. Do you or anyone else have any picture or could anyone explain where the cables should go
mike
A
P0036 P0056 P0137 P0157 2020 Ford Mustang GT
  • AmkoA
  • Jun 16, 2026
  • 2024+ (S650) Mustang -General/Talk
2024+ (S650) Mustang -General/Talk Jun 16, 2026
AmkoA
A
M
2001 v6 heater hose quick connect question
  • mnky99
  • Sep 24, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 26, 2025
mnky99
M
M
  • mnky99
  • Sep 5, 2025
mnky99
M
Vacuum line question?
  • Mustang Momma
  • Feb 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- Mar 3, 2026
D
Engine Coolant and Radio Issues
  • Don7Up
  • Sep 14, 2025
Fox 5.0 Mustang Tech Oct 4, 2025
Don7Up
D
