Heater Core drain?
  • Thread starter Thread starter Jaswir
  • Start date Start date Nov 10, 2007
Jaswir
578
Orlando, FL
Nov 10, 2007
  • Nov 10, 2007
I found coolant leaking out of a drain on the firewall just below the two lines that connect to the heater core! I take it my heater core is shot?
P
PRO50SC
1,012
Olney, Maryland
Nov 10, 2007
  • Nov 10, 2007
Yup, pretty much!!
Jaswir
578
Orlando, FL
Nov 10, 2007
  • Nov 10, 2007
thanks, thats what i thought... just gonna by-pass it im not taking out my dash to replace that... for now...
T
TokyoJoe
179
  • Nov 10, 2007
yep, no drain for the heater core, just a straight through. Double check your hoses on the firewall just to be certain.
P
PRO50SC
1,012
Olney, Maryland
Nov 10, 2007
  • Nov 10, 2007
http://www.mustangmonthly.com/howto/5652/index.html
Jaswir
578
Orlando, FL
Nov 10, 2007
  • Nov 10, 2007
well im leaking coolant out of a drain in the firewall down by the header? No drain? then why am i leaking coolant out of the firewall?
SuperStang83
1,693
Boyertown, Pa
Nov 10, 2007
  • Nov 10, 2007
weep hole
Jaswir
578
Orlando, FL
Nov 10, 2007
  • Nov 10, 2007
so is that my heater core? Do i need to change it or not? i got two different people saying things?
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Nov 10, 2007
  • Nov 10, 2007
More than likely, yes, the heater core is shot. The weep hole will drain coolant if the heater core is bad.
SuperStang83
1,693
Boyertown, Pa
Nov 10, 2007
#10
  • Nov 10, 2007
  • #10
Exactly what StangGT said. When the heater core goes it drains throught the weep hole so that it doesn't go into the car as much. You will need to replace it, and it really isn't as hard as everyone thinks. I just did one 2 weeks ago, and it wasn't that bad.
jammer84_03
468
#11
  • Nov 10, 2007
  • #11
for kicks and giggles, take both hoses off and take a garden hose to the outlet side and give a lil blast. over time my gummed up and i had an issue with it. one blast and i was good as new! but thats just my 2 cents on what i think was a lucky break.
P
PRO50SC
1,012
Olney, Maryland
Nov 10, 2007
#12
  • Nov 10, 2007
  • #12
That won't fix a leaking heater core!
T
TokyoJoe
179
#13
  • Nov 10, 2007
  • #13
lol, then he'll just be leaking water. Sorry for the confusion, all I meant was the core itself doesn't have an installed drain. but of course if it leakes inside that big plastic box it's going to funnel down to where you see it coming out thats all. And it's really not that big a deal to change. Just take your time and keep track of all the little boltscrews and pull slowly
Jaswir
578
Orlando, FL
Nov 11, 2007
#14
  • Nov 11, 2007
  • #14
i already bypassed it, thanks guys! I will replace it soon!
SuperStang83
1,693
Boyertown, Pa
Nov 11, 2007
#15
  • Nov 11, 2007
  • #15
LOL, no you won't.
Jaswir
578
Orlando, FL
Nov 11, 2007
#16
  • Nov 11, 2007
  • #16
lol, it will be awhile... i live in FL so don't really need it.... but i will replace it... When i took off one of the hoses to the heater core the metal piping came right off out of the firewall! So it was pretty bad... lol
RYC CUKR
1,437
Orlando
Nov 11, 2007
#17
  • Nov 11, 2007
  • #17
If you need a hand when you decide to replace it let me know. I have replaced them in my 88 and in my 93.
Jaswir
578
Orlando, FL
Nov 11, 2007
#18
  • Nov 11, 2007
  • #18
will keep that in mind! Thank's!
Engine Bleeding air in the heater core
  • keel
  • Apr 2, 2026
Fox 5.0 Mustang Tech Apr 23, 2026
limp
D
Engine Coolant and Radio Issues
  • Don7Up
  • Sep 14, 2025
Fox 5.0 Mustang Tech Oct 4, 2025
Don7Up
D
K
86 GT Water Pump
  • Kade5114
  • May 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 11, 2026
nickyb
M
2001 evap/heater core questions
  • mnky99
  • Sep 3, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 3, 2025
mnky99
M
A/C Issues
  • Boats90GT
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 11, 2026
Mcmahst
