Tip--When you replace the hoses and install new clamps, aim the heads of the clamps toward the driver's side, horizontal to the ground. That way, 10 years down the road when they need replaced again, all you need to do it remove the 4 nuts in the engine compartment plus the one that holds the air box in the air. You will be able to pull the assembly into the engine compartment a couple of inches, which is plenty to loosen the clamps, slice the old hoses, and then install the new stuff. I just completed the "10 year job" after doing this many years ago and the new hoses went on fairly smoothly--even with the console in place!
