heater core not hot
Allpro_5.0
i just recently replaced my heater core and now my heater just feels week. before it got really hot and i always had to turn it down now it take about 20 minutes for the winsheild to even start defrosting. the air coming out just isnt hot any more. its barely warm. ive tried a hotter thermostat and it made a little difference but not much. is there any thing i can do to fix this?
heater core
where did you get the heater core form? if its the cheapest one you could find its probably made out of the cheapest material out there and doesnt disapate heat very well. the factory ford peices are a made from i belive a copper/ brass / aluminum mix and dispurse heat very well. the cheap parts house ones just hold the heat in and let the hot water run through it. belive it or not the O.E. product is a better choice in this application. if you have a O.E. heater core i dont know what it could be. i know on some ford vehicles there is an inline coolant flow valve in the heater core lines that controls how much coolant flows through so you can adjust temp that way. its vacum controlled but i dont think 5.0's have this.
its possible that your new heater core has a built-in restrictor...to keep from blowing the core at high engine speeds. for the ford cores, the orifice was installed in one of the heater hoses. i am not sure if any cores come with them built in or not. but if you didnt have it before, and now you do, then that could make the heat come slower. you definitely should have one, if you dont. it is possible you have air trapped in the heater core as well. btw i have an advance auto parts heater core and a ford restrictor and it heats up pretty quick...but i have a 4 banger rad. :nonono:
the core
yea i bought an advance auto one and mine took awhile to get hot. and i dont have an inline restictor but when i finally got tired of it and got a ford core and swapped them out and that solved all my problems.
