heater core???
  • Thread starter Thread starter jgfiveoh
  • Start date Start date Dec 9, 2006
jgfiveoh
102
Topeka, KS
Dec 9, 2006
  • Dec 9, 2006
gonna be putting in a new dash this weekend. should i do the heater core while i'm in there? not sure if its ever been done before and i've never had a single problem with it. can u just inspect it while your under there or should i just replace the damn thing?
is it best to go to ford to buy the heater core or will a parts house on be ok?
RYC CUKR
1,437
Orlando
Dec 9, 2006
  • Dec 9, 2006
For what a heater core costs I would go ahead and replace it while the dash is out. It would suck to get it all back together only to find out it was bad or have it go bad a little bit down the road.
I would stick with a Ford heater core, I have heard from some that the parts store ones are thinner and go bad sooner.
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Dec 9, 2006
  • Dec 9, 2006
I would and make sure you use a flow restrictor
bubba-dough
1,044
Indiana
Dec 9, 2006
  • Dec 9, 2006
Personally I would change it while the dash was out, thats just me though. But then again if it ain't broke, don't fix it.
I have had to change a heater core in every Fox I have ever owned and I always got the replacement from the dealer and never had a problem with them. But I had to change the one in my 90 about 2 yrs ago, then again last year and finally about 2 months ago. They were all Ford ones. So sadly I just spent $15 instead of $45 and got one from a parts store.
srothfuss
Last night I stabbed the same guy 7 times in a row
Oct 17, 2004
1,796
Woodward Ave.
Dec 9, 2006
  • Dec 9, 2006
The H/C goes about evey 60K miles so if you don't know the mileage on the existing unit you might want to replace it to save the frustration later down the road.
Someone else mentioned it, but stick with an OEM part if you can find one.
The flow restrictor goes in the smal 3//8" hose that runs from the back of the lower intake to the inlet at the firewall (front of dash)
310stanger
170
  • Dec 9, 2006
Possibly a stupid question but whats the reason for using the flow restrictor? Does this produce better heating and lower the risk of "blowing" the core out?
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Dec 9, 2006
  • Dec 9, 2006
it dosnt let so much pressure build up in the heater core during high rpm's
Sompin2do
59
TX
Dec 11, 2006
  • Dec 11, 2006
Ditto on going ahead and changing it while you've got it torn down. I had to do my core so I canned the AC evap and converted to R134 also. Now I'm guttin the carpet and seats. If you get stuck, there's lots of info in here.
Good luck
Mike
A/C Issues
  • Boats90GT
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 11, 2026
Mcmahst
M
2001 evap/heater core questions
  • mnky99
  • Sep 3, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 3, 2025
mnky99
M
M
2001 v6 heater hose quick connect question
  • mnky99
  • Sep 24, 2025
SN95 V6 Mustang Tech Sep 26, 2025
mnky99
M
M
  • mnky99
  • Sep 5, 2025
mnky99
M
Copart :poo:Box
  • StepBro
  • Feb 13, 2025
  • The Welcome Wagon
The Welcome Wagon Feb 14, 2025
