  • SN95 4.6L Mustang Tech
Heater hose question...
  • Thread starter Thread starter cefolar
  • Start date Start date Aug 6, 2007
cefolar
15
  • Aug 6, 2007
I have a 4.6 DOHC motor and am working on my evaporator and heater core and wondered if anyone knew which of the 2 metal hardlines coming off the back of the motor was the outlet and inlet for the heater core.
1 line goes directly into the block and the other under the intake manifold to the front of the motor. I am assuming that the one to the front of the block is the pressure side and the other is the return?
I'll take any input I can get - thanks!!
Skud
493
Saskatchewan
Aug 6, 2007
  • Aug 6, 2007
I believe the hard line going to the front of the engine is the return line. It goes to the water pump.
So...
back of the head ---> heater core IN -----> heater core OUT ----> hard line to front..
So, you have HOT coolant from the back of the head going into your heater core, then it gets returned to the pump and recirculated..
I *think*...
Riley
M
2001 v6 heater hose quick connect question
  • mnky99
  • Sep 24, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 26, 2025
mnky99
M
M
2001 evap/heater core questions
  • mnky99
  • Sep 3, 2025
SN95 V6 Mustang Tech Sep 3, 2025
mnky99
M
Engine Heater hose restrictor purpose
  • Mcmahst
  • May 5, 2025
Fox 5.0 Mustang Tech May 11, 2025
limp
M
  • mnky99
  • Sep 5, 2025
mnky99
M
M
2001 v6 heater return pipe leak question
  • mnky99
  • Nov 11, 2025
SN95 V6 Mustang Tech Nov 11, 2025
mnky99
M
