  • 1994 - 1995 Specific Tech
Heater not working up to par
  • Thread starter Thread starter Brando8912
  • Start date Start date Feb 9, 2011
Brando8912
38
  • Feb 9, 2011
I got a question about the heater in my car. Its not getting very hot. Its working, kinda but compared to my truck i have its not very hot. I can have it on full blast and its just not up to par with the cold weather were having lately. My car runs cool could that be part of it or is the heater core just going bad?
revhead347
Apparently my ex-husband made that mistake.
20+ Year Stangneter
Jun 14, 2004
9,303
1,648
214
Acworth, GA
Feb 9, 2011
  • Feb 9, 2011
Usually a bad heater core just leaks. How cool does your car run. If the thermostat is jammed, then the water might not be getting up to temp. Are you running a high flow thermostat?
Kurt
Brando8912
38
  • Feb 9, 2011
Yeah i am running a mr gasket tstat replaced back in April. I cant remember if it was 160 or 180. On my dummy gauge on the dash i am at the "o" in normal. I have good clean fluids as they were all replaced a couple months ago and are still full.
revhead347
20+ Year Stangneter
Jun 14, 2004
9,303
1,648
214
Acworth, GA
Feb 9, 2011
  • Feb 9, 2011
Yeah, once you put the high flow Mr. Gasket thermostat in there the heater becomes useless. All the water flows to the radiator, and nothing gets up into the heater core. The only way to fix it is to put a stock thermostat back in, or put an electric pump in the system to pump water up to the heater core.
Kurt
Chythar
Recently finished repairing my rear
20+ Year Stangneter
Aug 26, 2004
2,373
140
113
Foothill Ranch, CA
Feb 9, 2011
  • Feb 9, 2011
Most folks recommend you don't go lower than 180 - stock is 190. 160 usually doesn't let the engine heat up enough to operating temp, and supposedly can cause excessive wear to the engine over time. If your stiock gauge is reasonable correct, being on the "o" is a good operating temperature.
The heater works directly off of coolant temperature. So by putting in a higher-flow thermostat, the coolant doesn't heat up as much thus reducing the heat output from the heater. I live in Los Angeles so I have no proper comparison to the cold most of the rest of the country is having, but it's entirely possible it's just so bitter cold that the heater just isn't putting out enough heat.
revhead347
20+ Year Stangneter
Jun 14, 2004
9,303
1,648
214
Acworth, GA
Feb 9, 2011
  • Feb 9, 2011
I can verify it is that thermostat. I've had both a 160 and a 180 in the car, and it made no difference. I have to wear a jacket when I drive my Mustang in the winter.
Kurt
Brando8912
38
  • Feb 10, 2011
Well i figured it might be that. I guess i will just have to deal with it til winter is over or i can do what i do now on cold days and drive the truck. Thanks guys!
Engine Bleeding air in the heater core
  • keel
  • Apr 2, 2026
Fox 5.0 Mustang Tech Apr 23, 2026
limp
A/C Issues
  • Boats90GT
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 11, 2026
Mcmahst
M
2001 v6 heater hose quick connect question
  • mnky99
  • Sep 24, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 26, 2025
mnky99
M
M
2001 evap/heater core questions
  • mnky99
  • Sep 3, 2025
SN95 V6 Mustang Tech Sep 3, 2025
mnky99
M
Engine Heater hose restrictor purpose
  • Mcmahst
  • May 5, 2025
Fox 5.0 Mustang Tech May 11, 2025
limp
