Heater Rail Delete?
  • Thread starter Thread starter GSXRMIXXER
  • Start date Start date Jun 6, 2007
GSXRMIXXER
97
  • Jun 6, 2007
ok guys help me out. im re-doing the top end of my motor and replacing the stock upper/lower intakes with cobra ones. well, while im at it i would like to remove the stock heater rails because i have no heater core/ assembly below the dash. i live in FL now and heat is not an problem! long story short does anyone have any ideas/pictures of what needs to be done (correctly) to completely remove all heating elements and clean up the top of my engine? how do i cap off the water pump outlet ? pics are great so please post. thanks in advance
Fett
766
  • Jun 6, 2007
Two words: De Frost. In Florida you will want it, it is amazing how quickly your windows fog up down here with the humidity. Just food for thought.
93 LX
3,081
Norwalk, CA.
Jun 6, 2007
  • Jun 6, 2007
If you have EFI then you will need a place for the ECT...
GSXRMIXXER
97
  • Jun 6, 2007
?? that is??
GSXRMIXXER
97
  • Jun 6, 2007
electric heater
Darkwriter77
Resident Ranting Negative Nancy
5 Year Member
Jul 1, 2005
315
283
134
Apache Junction, AZ
Jun 6, 2007
  • Jun 6, 2007
You'll need a small plug for the back of the intake where the TB spacer coolant line used to go (1/4" NPT, IIRC) and a brass bushing to plug your ECT sensor into the front of the intake where your heater pipe used to go in - not sure of the diameter (sorry, I'm senile), but go raid the Dorman drawers of your local Autozone and you'll find it in there. Also, you'll need a hose nipple cap for the extra water pump outlet that you won't be using; you can either use a formed rubber cap (also at Autozone, in the coolant-related goodies aisle) or just take a short bit of heater hose with a big fat bolt slathered with RTV silicone sealant shoved and clamped into the end of it ... and be sure to use good stainless steel hose clamps to secure everything.
DO NOT try to use a little vacuum cap to plug that back nipple on the rear of the intake, even with a little hose clamp. That thing can see way more pressure than a vacuum cap can contain, and I found out the hard way when I went WOT one time and that sucker popped, spewing coolant allllllll over underhood. ("So much blood for such a tiny little hole..." )
93 LX
3,081
Norwalk, CA.
Jun 7, 2007
  • Jun 7, 2007
GSXRMIXXER said:
?? that is??
Engine Coolent Temperture sensor.
This is how the ECC knows when the engine is cold or hot.
RYC CUKR
1,437
Orlando
Jun 7, 2007
  • Jun 7, 2007
This is exactly what I did when I put the ECT back in after the previous owner removed it and the heater hardlines.
vikingpower
656
CWU Ellensburg, WA
Jun 8, 2007
  • Jun 8, 2007
If you keep the heater, remove the hard lines and use heater hose, its a lot easier to service the engine. I cut the part with that sensor thing off and kept that, then ran the rest with rubber hose.
89Notch
1,669
MSU
Sep 30, 2007
#10
  • Sep 30, 2007
  • #10
I hate to hijack the thread but...
I have a carb'd engine and plan on removing the heater rail. Are you saying to plug the outlet off the water pump all you have to do is put a nipple cap with a clamp over it and that is good enough to hold the pressure? Thanks
M
2001 evap/heater core questions
  • mnky99
  • Sep 3, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 3, 2025
mnky99
M
M
  • mnky99
  • Sep 5, 2025
mnky99
M
J
Engine Running like crap :(
  • justadude07
  • Sep 27, 2025
Fox 5.0 Mustang Tech Oct 19, 2025
DadLife0724
M
2001 v6 heater return pipe leak question
  • mnky99
  • Nov 11, 2025
SN95 V6 Mustang Tech Nov 11, 2025
mnky99
M
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
