heatercore busted
  • Thread starter Thread starter TooFoxy
  • Start date Start date Oct 26, 2005
T
TooFoxy
58
Charleston SC
Oct 26, 2005
  • Oct 26, 2005
yesterday on way to work i get strange smell of coolant... got stoped at a light so i open the door and stick my head underneath the car and its only berely dripping out so i drove it the rest way to work never got hot.... but after work i discover that its the heatercore... the lil "weephole" yea so i know what my weekend consist of only one question... i know i can do the heater core but the evaporitve core i think i should replace this also and i have no clue about how to change it. when i turn my a/c on it gets cold but it blows alil mist out w/ it... is that the evap core? anyone know what to do to change it?
J
Juicer
37
  • Oct 26, 2005
good luck dude. just bypass the heater core. if you replace it it will take about a month before you need a new one. and no you dont have to replace the evaporator.
1988WHTGT
270
Guyton, GA
Oct 26, 2005
  • Oct 26, 2005
Putting in my heater core was the worst time I had in my life....good luck man.
89stangWhiz
104
Mechanicsville, MD
Oct 26, 2005
  • Oct 26, 2005
Bypass the heater core? Where do you live, Florida, Texas? Even when I was in FL i needed the heat early in the morning!
Replace it in a month? Why do you say that? If the stock one lasted 10-15+ years why would another only last a month?
RN7676
  • Oct 26, 2005
heatercore replacement
The heater core and A/C evaporator are unrelated components and systems. They are both part of the climate control system, but other than that, they are essentially unrelated to each other. I wouldn't mess with the A/C evaporator if the A/C still works.
I beleive the heater core is factory installed before most of the dash components, so getting it out could be a serious task depending on how you want to approach it.
Check this site:
http://www.mustangsteve.com/heatercore.html
bubba-dough
1,044
Indiana
Oct 26, 2005
  • Oct 26, 2005
The evaporator core sits right beside the heater core in the same housing, so if you want to change it, I would while you are there since you are getting condensation. http://users2.ev1.net/~calley/Sally/heater_core/ That will tell you how to change both. Its not hard at all. And as long as you do it correctly with good parts and you use flexible gasket maker on the heater core it will last.
Don't use some cheap a** parts store parts go to the dealer.
J
Juicer
37
  • Oct 26, 2005
im from southern california maybe thats why. anyhow i replaced my heater core twice in the past. the first one lasted 3 months and the last before giving up lasted only 1 month. and i do have the restrictor. you've had some pretty good luck. most people here have already been though this crap
D
Engine Coolant and Radio Issues
  • Don7Up
  • Sep 14, 2025
Fox 5.0 Mustang Tech Oct 4, 2025
Don7Up
D
M
  • mnky99
  • Sep 5, 2025
mnky99
M
M
2001 v6 heater return pipe leak question
  • mnky99
  • Nov 11, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Nov 11, 2025
mnky99
M
M
2001 v6 heater hose quick connect question
  • mnky99
  • Sep 24, 2025
SN95 V6 Mustang Tech Sep 26, 2025
mnky99
M
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
