  • 1994 - 1995 Specific Tech
HEATING SPRINGS
  • Thread starter Thread starter larry_wayne_5.0
  • Start date Start date Nov 2, 2004
L
larry_wayne_5.0
monticello, ar
Nov 2, 2004
  • Nov 2, 2004
alright i know im pratically asking for it with this post, but please don't lecture me about how i shouldn't do it and how i will regret it, i just want to know what is the "proper" way to heat your springs to lower the car. i have an extra set of springs so if i mess up ill just putt the new ones in. the car is a 95. the tool i will be using is a butane torch. thanks peeps, halla
R
RyClef331
118
Jacksonville,NC
Nov 2, 2004
  • Nov 2, 2004
Just cut'em if you're going to get cheap with it. I don't know if a butane torch has enough "ass" behind it to even heat the spring enough. But if it does, just keep the weight of the car on the spring and heat up a section until you get the height you want.
D
Drunk5oh
99
ocala fla
Nov 2, 2004
  • Nov 2, 2004
this is completely second hand knowledge, but i would put something under the car to avoid heating the springs too much and having the wheels plant themselves in the wheelwell
Grandmaster
374
Monticello, Arkansas
Nov 2, 2004
  • Nov 2, 2004
ttt
-GM
chefster
426
michigan
Nov 2, 2004
  • Nov 2, 2004
one of the funniest things ive read on this forum,except of course for the birdhousecomment during the hurricane..dont even think about it ..go watch tv or something
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
Nov 2, 2004
  • Nov 2, 2004
wont that melt the powdercoating off?
94CobraPace
907
Houston, Tx.
Nov 3, 2004
  • Nov 3, 2004
Heating springs to lower the car is difficult to get all the springs to lower the same amount. If you are going to cut the springs, then it is best to use a cut off wheel. Cutting with a torch can heat them up & get different drops on each spring. I'd recomend you cut them, not heat them to get the drop.
RECEIVED OFFER TO BY MY 92 LX CONVERTIBLE
  • 92StangGirl
  • Mar 23, 2026
  • What is it Worth?!?!?
What is it Worth?!?!? Mar 23, 2026
General karthief
Paint and Body Frame rail dimensions
  • keel
  • Jan 30, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 13, 2026
keel
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
water pump installation questions
  • B0udreaux
  • Feb 5, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 28, 2026
General karthief
M
2001 v6 heater return pipe leak question
  • mnky99
  • Nov 11, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Nov 11, 2025
mnky99
M
