Hellion recommendations
281cammer
34
I'm SERIOUSLY considering a Hellion 76mm kit for my 96 Cobra. My question is in regards to fuel system. My original thoughts were for 60lb injectors and a 255lph pump with a SCT2800 or a Lightning MAF. But due to boost/power levels I'm wanting some have said the 255 and the Lightning or SCT2800 won't be enough. I'm wanting to run around 18 psi. Any help/opinions would be greatly appreciated
Thanks
Steve
Hope you have a built bottom end for 18 psi. I'd do cobra tank/pumps from an 03 Cobra, or you can go with the twin Ford GT setup that some people have, along with 60# or 72# injectors. How much HP you plan on making is dependent on the type of MAF you can run and if your gonna ping it.
