Hellion Twin Turbo Install And Now Maf Issues
syck GT
Hey everyone.
I installed a hellion twin turbo kit on my 2016.
Going to try and tune it and the MAF readings are coming out lower then stock.
Just seeing if anyone has run into an issue like this with this kit or any other turbo kit.
Also a boost leak test has been done twice. She is making a solid 7psi.
Thanks in advance!
Sent from my SAMSUNG-SM-N920A using Tapatalk
  • Sponsors(?)
84Ttop
Mod Dude
Jul 2, 2009
5,329
3,349
204
South Jersey
Is this a blow through or draw through MAF? In know in the coyote blower applications I use the stock sensor in a blow through 4" housing. I also use a honeycomb before the MAF to straighten the air for a better signal. 11psi and 676rwhp and zero issues.
syck GT
Good question. All I know is every other person with this kit I have talked to used the stock MAF with no issue. Lol so I am not sure
84Ttop
Mod Dude
Jul 2, 2009
5,329
3,349
204
South Jersey
Was the harness cut and spliced at all or is it stock length? I've also seen poor solder connections give issues when harnesses are extended.
Have you tried to call Urist to see what there take is on this?
Reactions: syck GT
syck GT
Stock length. No cutting or extending needed.
I have called hellion twice and 1 other shop with no luck. They keep saying boost leak but I have verified multiple times there is no leak.
15GTrob
Advanced Member
Aug 23, 2015
450
124
73
34
I was only asking because I'm not sure how you would test that.
syck GT
Oh no worries.
Basically remove both air filters. Put a special cap on one turbo to block it off and then a cap on 2nd turbo with a fitting to allow you to use air compressor to pressurize system.
Turned up to 25psi and it held no issues
Thread starter Similar threads Forum Replies Date
D Hellion Twin Turbo Air Conditioning Issue 2010 - 2014 Specific Tech 1
Hellion2013 For Sale 2013 Hellion Twin turbo Mustang GT S197 Mustangs For Sale (2005-14) 0
M Expired Hellion Twin Turbo 2016 Mustang Gt Premium S550 Mustangs for Sale (2015+) 2
G hellion twin turbo advice? SN95 4.6L Mustang Tech 20
C Expired 65mm Hellion Turbo Kit Engine and Power Adder Parts 4
B Bought A 2008 Mustang Gt With A Hellion 62mm Turbo Kit Need Instruction 2005 - 2014 S-197 Mustang -General/Talk- 3
E Drivetrain Swap With Hellion Install The Welcome Wagon 2
jcyamaharider Hellion Turbo Kit For 2015??? 2015+ (S550) Mustang -General/Talk 2
R Hellion Turbo...what To Do Next? 2005 - 2009 Specific Tech 4
R SOLD 2007 Gt W/ 76mm Hellion Turbo Kit For Sale S197 Mustangs For Sale (2005-14) 0
Ltngdrvr Sneak Peak, Hellion 2011+ V6... 2005 - 2014 S-197 Mustang -General/Talk- 2
A Ordering Hellion Turbo kit tommorrow, advice on install price and water/meth kit 2005 - 2014 S-197 Mustang -General/Talk- 4
drumpro506 Hellion Turbo kit f.s Engine and Power Adder 5
B 2001 HELLION TURBO GT - $45k+ IN RECEIPTS - FRESH MOTOR/TRANS - MUST GO SN95 Mustangs For Sale (1994-04) 0
I HELLION TURBO 2000 MUSTANG GT FOR SALE 600 HP PUMP. 12500 OBO SN95 Mustangs For Sale (1994-04) 2
JymboSlice Hellion 62mm kit 1996 - 2004 SN95 Mustang -General/Talk- 5
jonathan6486 2003 COBRA SVT WITH HELLION TURBO SN95 Mustangs For Sale (1994-04) 11
B FS: Hellion T76 Turbo Kit Engine and Power Adder 2
J Hellion Turbo SN95 4.6L Mustang Tech 5
S hellion turbo 1996 - 2004 SN95 Mustang -General/Talk- 0
C Brenspeed Hellion Turbo vs Brenspeed Saleen Supercharger vs Brenspeed Vortech Charger 2005 - 2009 Specific Tech 22
Radman Hellion Turbo 2005 - 2009 Specific Tech 7
04MystiCobra Hellion "Heat" kit for 5.0 Regional Forums and Event Information 11
FoxRod87 Hellion Turbo Power? 2005 - 2014 S-197 Mustang -General/Talk- 3
8 2004 cobra hellion turbo kit idle problem and stalling ! SVT Tech Forum 1
F hellion and turbonetics turbo kits? 2005 - 2009 Specific Tech 4
281cammer Hellion recommendations SVT Tech Forum 0
281cammer Hellion recommendations SN95 4.6L Mustang Tech 2
K Hellion Turbo 2005 - 2009 Specific Tech 2
0 Anyone here have the Hellion Turbo kit in Los Angeles? 2005 - 2009 Specific Tech 2
R Hellion power and required/recommended upgrades? 2005 - 2009 Specific Tech 1
G HP vs. Hellion SN95 4.6L Mustang Tech 2
C Hellion turbo 1996 - 2004 SN95 Mustang -General/Talk- 1
postban 18psi Whipple vs 18psi Hellion SVT Tech Forum 2
D Calling all hellion kit users Fox 5.0 Mustang Tech 0
0 Just open the boxes for my new hellion turbo ki Regional Forums and Event Information 15
Joey5.0 Anyone Got A Hellion Turbo Kit On There Fox? Fox 5.0 Mustang Tech 16
C For Sale Garrett twin turbo kit + injectors Engine and Power Adder 1
metal mike What's it Worth? 1996 mustang twin turbo What is it Worth?!?!? 3
metal mike 1996 mustang twin turbo 1996 - 2004 SN95 Mustang -General/Talk- 1
S Best shop in twin cities 2005 - 2014 S-197 Mustang -General/Talk- 0
2000xp8 McLeod twin disc meet the hype? Update: We're going to find out... 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 29
C 62mm Twin BBK throttle body 06 Mustang GT 2005 - 2009 Specific Tech 8
metal mike new guy 1996 mustang 4.6 twin turbo The Welcome Wagon 2
C On3 top mount twin turbo kit 2015+ (S550) Mustang -General/Talk 1
I Twin charging a v6? 1996 - 2004 SN95 Mustang -General/Talk- 0
T Twin turbo install 1996 - 2004 SN95 Mustang -General/Talk- 0
W Twin Turbo Install Need Some Advice Fox 5.0 Mustang Tech 17
Machme72 New Edge Coyote Swap F150 Vs Stang Setup (twin Turbo) 1996 - 2004 SN95 Mustang -General/Talk- 3
W Need Turbo Information Fox 5.0 Mustang Tech 4
