Hello my Mustang Gt friends; please help me
iamturboed
15
1995 Mustang GT 5.0 HO vert...drove home from work, next day car won't start and still won't start...same everytime I try. Car turns over but will not start:
Checked for OBD I codes: there are none
Have spark all the way to the plugs
fuel pressure is 40psi
ignition switch is good
noid light flashes when checking injection pulse.
NOTE: the one and only thing I find that seems strange is the noid light flashs multiple times throughout 2 rotations of the crankshaft......I was expecting only one flash during 2 rotations.
FYI the crank turns, the stator turns, timing checked while turning the motor over shows 9 degrees BTDC
Everything seems correct but car will not start.
I tried spraying starter fluid in the intake to make it fire up....nothing. Now that I think about it, it should have fired at least for a little while. I'm going to try it again tonight.
The only thing left I can think of assuming that your sparking at the right time and injectors are ok is that your IAC went bad and you aren't getting any air into the engine. Try starting it like a carbed car and open the throttle. It won't run well, but see if it will turn over.
Thanks, I tried that as well, it turns over but still will not start. Do you know how many ignition pluses you should see when testing with a noid light. I'm pulsing way more times then once during a complete cycle. (compression stroke)
Just to check, when you tested for OBDI codes, did you test under the dash or behind the passenger shock tower in the engine bay? It's a common mistake to check under the dash, even if you know it's an OBDI car.
Timing stock is 10*BTDC, but 1* off won't keep you from starting.
Are you actually getting fuel? I realize you say you have 40psi but it just sounds like you aren't getting fuel.
It's impossible to get an OBD1 scanner hooked up to the OBD2 port under the dash. That's like trying to stick the cylindrical block through the square hole when you're a child. Just a long shot guess, but do you still have cats on the car?
My guess is a bad ignition coil or a bad ignition control module. Just because it's sending a pulse, doesn't mean you have enough spark. If you go to Wells Ignition online, they have data for the tolerances for a stock ignition coil. You can test it if you have a basic multimeter.
Kurt
Thank you for the response......I have an OBD I & II scanner.....connected to OBD II with OBD II scaner, no communication. Connected to OBD I under hood on the passenger side....no codes present.
I am getting spark, tested to ground with the plug, good blue spark.
Matt, yes I don't think the injectors are working properly and there not shooting gas.....but everything seems right execpt the multiple pulses on the injector plug.
I'm going to go outside right now and spray starter fluid in the intake and see if if fire.
If I have spark and it has starter fluid does everyone agree it should fire up?
I'll be back in about 20 mins.
okay checked for spark on two plugs both have spark......sprayed starter fluid in the intake and cranked it over not even a sign of firing......how is that possible?
If you have fuel and you have spark its got to explode, right? What the heck is going on?
Can you hear the fuel pump priming? Might want to check that if you are positive you have spark.
If all else fails follow this checklist
1.) Remove push on connector from starter solenoid and turn ignition switch on. Remove the coil wire from distributor & and hold it 3/8” away from the engine block. Use a Metal Jumper to connect the screw to the big bolt on the starter solenoid that has the battery wire connected to it. You should get a nice fat blue spark.
No spark: Possible failed items in order of their probability
MSD or Crane ignition box (If so equipped)
Coil
TFI Module
PIP sensor in distributor. The PIP sensor supplies the timing pulse to trigger the TFI and injectors. See paragraph 5A - a Noid Light will tell if the PIP is working by flashing when the engine is cranking.
No ECC or Computer Power - ECC or computer relay failure
86-93 models only: ECC relay next to computer - look for 12 volts at the fuel injector red wires
No ECC or Computer Power - Fuse or Fuse link failure
86-93 models only: Fuse links in wiring harness – Check to make sure that there is 12 volts at the fuel injector red wires. All the fuse links live in a bundle up near the starter solenoid.
Ignition switch - Look for 12 volts at the Ignition Coil Red/Light Green wire. If it is not reading 12 Volts: possible blown fuse link or faulty ignition switch. Remove the plastic from around the ignition switch and look for 12 volts on the red/green wire with the switch in the Run position. If there isn’t 12 volts then the ignition switch is faulty. If 12 volts is present in the Run position, then the fuse link is blown.
Bad or missing secondary power ground. This ground is located between the back of the intake manifold and the driver's side firewall. It supplies ground for the alternator, A/C compressor clutch and other electrical accessories such as the gauges.
Computer
Engine fires briefly, but dies immediately when the key is released to the Run position: Pull the small push on connector (red wire) off the starter relay (Looks like it is stuck on a screw). Hold the switch in the crank position: if it continues to run there is a problem with either the ignition switch or TFI module. Check for 12 volts at the red/green wire on the coil with the switch in the Run position. If reading 12 volts, then replace the TFI. If not reading 12 volts, replace the ignition switch.
Spark at coil wire, pull #1 plug wire off at the spark plug and Check to see Spark.
2.) No spark, possible failed items in order of their probability:
Moisture inside distributor – remove cap, dry off & spray with WD40
Distributor cap
Rotor
Spark Plug wires
Coil weak or intermittent - you should see 3/8" fat blue spark with a good coil
Next, get a can of starting fluid (ether) from your local auto parts store: costs vary depending upon Brand and Size. Pull the air duct off at the throttle body elbow, open the throttle, and spray the ether in it. Reconnect the air duct and try to start the car. DO NOT TRY TO START THE CAR WITHOUT RECONNECTING THE AIR DUCT.
Two reasons for this
If it starts then, you have a fuel management issue. Continue the checklist with emphasis of fuel related items that follow. If it doesn’t, then it is a computer or timing issue.
Clue: Listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 5-20 seconds and shut off. To trick the fuel pump into running, find the EEC test connector and jump the connector in the Upper RH corner to ground. The EEC connector is near the wiper motor and LH hood hinge.
If the relay & inertia switch are OK, you will have power to the pump.
Check fuel pressure – remove the cap from the schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. Beware of fire hazard when you do this. In a pinch, you can use a tire pressure gauge to measure the fuel pressure. It may not be completely accurate, but you will have some clue as to how much pressure you have. If you have any doubts about having sufficient fuel flow/pressure, rent a fuel pressure test gauge from the auto parts store. That will tell you for sure if you have adequate fuel pressure.
4.) No fuel pressure, possible failed items in order of their probability
Tripped inertia switch – Coupe & hatch cars hide it under the plastic trim covering the driver's side taillight. Use the voltmeter or test light to make sure you have power to both sides of the switch
Fuel pump power relay – located under the driver’s seat in most Mustangs built before 92. On 92 and later model cars it is located below the Mass Air Flow meter. Look for 12 volts at the Pink/Black wire on the fuel pump relay.
Clogged fuel filter
Failed fuel pump
86-90 models only: Blown fuse link in wiring harness. Look for 12 volts at the Orange/Lt Blue wire on the fuel pump relay.
Engine seems to load up on fuel and may have black smoke at the tailpipe. Fuel pressure regulator failed. Remove the vacuum line from the regulator and inspect for fuel escaping while the pump is running. If fuel is coming out the vacuum port, the regulator has failed. Check the regulator vacuum line for fuel too. Disconnect it from the engine and blow air though it. If you find gas, the regulator has failed.
A noid light available from any auto parts store, is one way to test the injector wiring.
The noid light plugs into the fuel injector harness in place of any easily accessible injector. Plug it in and it will flash if the injector is firing.
[jrichker likes] to use an old injector with compressed air applied to the injector where the fuel rail would normally connect. [jrichker would] hook the whole thing up, apply compressed air to the injector and stick it in a paper cup of soapy water. When the engine cranks with the ignition switch on, if the injector fires, it makes bubbles. Cheap if you have the stuff laying around, and works good too. [Not certain about this step]
Pull an injector wire connector off and look for 12 volts on the red wire when the ignition switch is on.
No power, then look for problems with the 10 pin connecter (salt & pepper shakers at the rear of the upper manifold).
No power and the 10 pin connections are good: look for broken wiring between the orange/black wire on the ECC relay and the red wire for the 10 pin connectors.
TPS voltage exceeds 3.7 volts with the throttle closed. This will shut off the injectors, since the computer uses this strategy to clear a flooded engine. Use a DVM, a pair of safety pins, and probe the black/white and green wires to measure the TPS voltage.
It should be .5-.99 volts with the key on, engine not running. Note that if the black/white wire (signal ground) has a bad connection, you will get some strange readings. Make a second measurement using the battery post as the ground to eliminate any ground problems. If the readings are different by more than 5%, you may have a high resistance condition in the black/white signal ground circuit.
6.) Spark & fuel pressure OK.
Failed IAB (no airflow to start engine). Press the throttle ¼ way down and try to start the car.
Failed computer (not very likely)
Engine ignition or cam timing off (only likely if the engine has been worked on recently)
Firing order off: HO & 351 use a different firing order from the non HO engines.
HO & 351W 1-3-7-2-6-5-4-8
Non HO 1-5-4-2-6-3-7-8
No start when hot - Press the throttle to the floor & try starting it if you get this far. If it starts, replace the ECT.
Engine that has had the heads off or valves adjusted. Do a compression test to make sure the valves are not adjusted too tight. You should have a minimum of 90 PSI on a cold engine.
okay sitting here thinking about this........the camshaft must have jumped a tooth. Everything would check okay except when on the compression stoke right before it should ignite the valve opens up releases all compression then it tries to fire with no result because there is no compression.
I will do a compression check tomorrow night to see if this is correct.
Thanks for making me think everyone!
Don't get too far ahead of yourself. On a 94-95, a bad MAF or disconnected air inlet tube/MAF can keep a car from starting. A stuck-open EGR valve can do the same. There are little things like this which can keep it from starting.
And you need to figure out why you didn't get any codes - you should have gotten 111's at a minimum.
wouldnt the cam have to jump a lot more than just a tooth? I mean...dont u retard/advance cams by adjusting by a couple teeth when installing the timing chain?
Hello my friends;
Since I started this I guess I better see it though.....checked compression on 4 of my eight cylinders all have 100 psi....figured I could not have slipped a tooth nor could my cam shaft be broke. Sorry sorcerer, yes I do have the 111 code letting me know there are no trouble codes. After the compression check I replaced the MAF sensor with a known bad one....rescanned with the OBD I......picked up the bad MAF in a New York minute. Replaced the bad MAF with the original and scanned again.....111 all systems good. Tried to run the "engine on" scan while turning the motor over with the battery......don't know what else to do!!! ended up with a DTC 11 altitude circuit open.....will look this up right after I get done with this update. I don't know if this is bad or good, oh I might have forgot to mention I live at 7250 ft. And by the way, I hate to say, my air filter was black.....left it out for the last scans.
Sorcerer talk to me!!!
