Helmet questions
  • Thread starter Thread starter Brandon11010
  • Start date Start date Mar 16, 2009
Brandon11010
71
  • Mar 16, 2009
Alright so i finally broke into the 13's now i need to buy a helmet.. the track says i need a Snell 2000 or higher.. Now i see Snell SA2005.. is that higher? and where can i find one for as cheap as possible.. has to have a snell tag inside the helmet not just a sticker.. can anyone point me in a good direction?
Darkwriter77
Resident Ranting Negative Nancy
5 Year Member
Jul 1, 2005
314
281
134
Apache Junction, AZ
Mar 16, 2009
  • Mar 16, 2009
Summit Racing or Jegs.
Brandon11010
71
  • Mar 16, 2009
there all kinda spendy... on a student budget
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Mar 16, 2009
  • Mar 16, 2009
Call and see if they'll allow a Snell rated motorcycle helmet in lieu of the automotive version. You can probably pick one up cheaper.
Brandon11010
71
  • Mar 16, 2009
yea i think motorcycle helmests are cool as long as its snell 2000
BlownFiveLiter
18
108
Chicagoland
Mar 17, 2009
  • Mar 17, 2009
Make sure to double check first. They could still fail you for tech, if they won't allow motorcycle helmets.
bynummustang
Seen my other Jackstand?
Jul 24, 2005
NC State University
Mar 17, 2009
  • Mar 17, 2009
Just call and ask your local track what would pass.
DocG
5th graders > me. They're not bant
Sep 25, 2005
8,297
1,358
194
Cincinnati area
Mar 17, 2009
  • Mar 17, 2009
I'm in the same situation. I need to pick up a helmet before I can hit the track. I used to have one when I had a motorcycle and it was pretty cheap, but I'll be damned if I remember the size to be able to order one online.
Good luck man.
ej95cobra
82
Southeastern PA
Mar 17, 2009
  • Mar 17, 2009
As noted above, confirm if you can use an M (motorcycle) helmet or if you need an SA (sports application) rated helmet. SA is considered above an M helmet. I used s Shoei Snell M2000 at Englishtown with no problems. I also use it for autocrossing. I will be going to an HPDE where they required an SA rated helmet so I just bought a SA2005. Ratings will include Snell specifications with years of the spec; ex:2000 and 2005; I believe 2005 is the latest spec. Most places will want the helmet to be only 1 or no more than 2 models out. Hope this helps.
blackened88lx
Connecticut
Mar 18, 2009
#10
  • Mar 18, 2009
  • #10
I'm sure they will allow a motorcycle helmet if it's Snell approved. I don't see any reason they wouldn't. We have used motorcycle helmets with no issue but that was kind of a back woods redneck track. I would go to your local Honda, Suzuki, Yami or Kawi dealer and find a cheap Snell approved motorcycle helmet. You can get an HJC for around or a tad over $100.
Tire size question 1986 gt hatchback
  • B0udreaux
  • Jan 12, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 17, 2026
B0udreaux
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
G
New, 2005 Red V6 Convertible
  • Ginger2005
  • Jan 3, 2026
  • The Welcome Wagon
The Welcome Wagon Jan 4, 2026
2Blue2
A
Procharger install/prep questions
  • ahratrew
  • Nov 22, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Nov 26, 2025
Hard to start when engine is cold
  • 86_Capri
  • Mar 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
