  • SN95 4.6L Mustang Tech
Help! 4 valve timing/cam sprockets
  • Thread starter Thread starter cavepony
  • Start date Start date Jul 5, 2006
C
cavepony
49
Jupiter
Jul 5, 2006
  • Jul 5, 2006
Pardon the questions, but I think I may be out thinking myself here.
I am pulling the heads on the old motor to put on the new block.
I have the crank tool in the keyway slot and on the stud on the block with the RH cam sprocket timing mark at 11 and LH at 12.
However, the copper links on the cam chains are not lined up with the cam sprocket timing marks. I know when I install them the copper links should be aligned at the cam sprocket marks. Is this a problem for removing the heads?
Another question. On the new short block, I have #1 piston at TDC based on the position, but how do I know this is the exhaust stoke or does it not matter?
Thanks!
Timing chain, guides and tensioner installation (Possible orientation in Intake Stroke)
  • StallionMax
  • Sep 21, 2025
SN95 4.6L Mustang Tech Sep 24, 2025
StallionMax
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
J
MEED HELP!! 86 mustang
  • Jacob0121
  • Jan 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 25, 2026
CAMTWO1070
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
