Hey guy's, my buddies got a 94 Cobra with some mods. S-trim,30 lb inj,MSD 6al,BTM,255lph pump,all the exhaust is BBK,75mm mass air, 70mm throttle body,etc..The car was running fine until a week ago. It starts up fine,then after about 10 seconds the idle drops, it backfires, sputters.It feels like it loads up on fuel. I checked the ignition,fuel pressure, compression test,replaced plugs, checked for codes, check engine light does not come on
even though it runs horrible.Everything so far has checked out ok. If I shut it off and turn it on again it idles and drives right for a few seconds then starts to stumble again.I have no idea what it could be, any ideas are appreciated..thanks...
himself
