HELP!!! Another Vibration issue!!
  • Thread starter Thread starter iaff284
  • Start date Start date May 20, 2007
I
iaff284
29
Champaign, IL
May 20, 2007
  • May 20, 2007
Okay here's the deal. I have a 95 gt vert. I had a friend who found a "good deal" on a used set of rear gears for my 8.8. I rebuilt the entire rear including bearings, seals, and the trac loc. My friend set the gears up using measurements off the old pinion. Since they were installed the rear has had a low volume howl upon coast and light throttle. shortly after install a vibration has appeared that vibrates through the seat and into the front end. I have put the car up on jack stands and run it in gear. All I can here is a oscillating hum from the driveshaft, the howl from the gears at coast and light throttle, and a clunk when the trans shift gears that sounds like it's coming from the rear. I have checked the ujoints and there is no play but there does seem to be a little play in the tailshaft before it engages in the tranny. My questions are:
1. Can the pinion being out of alignment cause a vibration.
2. Can I use the proform or summitt pinion depth tool to reshim the pinion to the correct depth without knowing where the origional pinion was.
3. I know the driveshaft is out of balance but there was no vibration when the car was on the jack stands. Could the balance cause the vibration under load?
Thanks for you help all!!
91 HATCH
Banned
May 17, 2007
262
illinois
May 20, 2007
  • May 20, 2007
the driveshaft could cause some vibration but i think your gears are not setup right a summit pinion depth checker would work for setting them up right you just need the specs and some marking compound
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
Eight inches is enough for me...
  • 351MooseStang
  • Nov 27, 2025
1974 - 1978 Mustang II Talk & Tech Mar 2, 2026
Bullitt347
C
Drivetrain T-5 transmission issue
  • Ch3No2
  • Jul 11, 2025
Fox 5.0 Mustang Tech Jul 18, 2025
2000xp8
N
Vibration issue
  • Nicolaj
  • Apr 14, 2024
2K
Classic Mustang Specific Tech Nov 8, 2024
AeroCoupe
