The 351 swap is supposed to be a pretty straightforward process, but there are some differences because of the taller deck on the 351. Physically, it'll bolt right in and keep the same transmission. If it's not a roller block and you wish to run a roller cam, you'll end up having to convert it to roller lifters. You'll need a different distributor and lower intake because of the taller deck height, and I'm not certain, but I believe the 5.0 accessory brackets can be made to work. The biggest problem you may encounter is finding 351 headers that will work with the GT40P heads. Nate is correct, too; you'll have to drill the heads for 1/2" head bolts instead of the 5.0's 7/16" bolts. You could probably get away with using a standard set of swap headers with 90° plug boots and a cut plug socket for access, but I can't verify that since I haven't personally done the swap.
