Electrical Help! battery/wiring problem.
mdavidson101
Michigan
Hi guys, I have a 1997 mustang GT 99 4.6 PI motor. I was replacing my terminal end on the negative side, the end would no longer tighten onto the battery. Well I drove it to the auto parts store just fine, and shut it off. Got back in tried to start and get a *click* So I got out wiggle the battery cable and it fired right up. Get home and cut the end off and put the new end on and I connect the battery and get the fuel pump I think running. My battery light is blinking and the gas and temp gauges are stuck maxed out. I tried swapping batteries still nothing, hooked it up to a battery charger and still nothing. I have a pretty meaty sound system in it, but I've unhooked it thinking that was the problem. I have no burnt fuses and the wiring looks good/ not burnt or open.
If anyone has any experience with this or might be able to help I would really appreciate it, I'm a full time student with a part time job and this is my only car.
  • Sponsors(?)
Thread starter Similar threads Forum Replies Date
ga289stocker Battery relocation wiring question???help.... Classic Mustang Specific Tech 3
mytight95 Battery Relocation............wiring help 1994 - 1995 Specific Tech 9
C HELP w/ wiring a battery disconnect switch Fox 5.0 Mustang Tech 5
Mycelus Dead battery, need help with some questions 2010 - 2014 Specific Tech 1
Drum4life23 I have a very interesting situation! 06 mustang won’t start unless I remove fuse HELP! 2005 - 2009 Specific Tech 4
Russ Cochran I need some help with a charging problem on a 04 gt SN95 4.6L Mustang Tech 6
Anti_Hero0932 Battery Relocation Fail - HELP Fox 5.0 Mustang Tech 14
starstruck106 Need Help 1995 Convertible 3.8 Temp Gauge still not working and alarm system is draining my battery 1994 - 1995 Specific Tech 11
Hudson N My 1991 keeps dying, help. Fox 5.0 Mustang Tech 12
utemachine Help identifying this connector to the battery negative 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 3
Mstng93SSP Help With Battery Cables 1994 - 1995 Specific Tech 3
J Help! Battery Relocation Cable/fuse Size Issues?!?! Fox 5.0 Mustang Tech 19
T Mach 460 Help Needed Mustang Sound & Shine All 1
D Help Please 1996 - 2004 SN95 Mustang -General/Talk- 10
J Please Help Can Not Figure Out Electrical Problem 1996 - 2004 SN95 Mustang -General/Talk- 1
MrFoxNutCase Help: Anyone Have A High Res Pic Of A Stock Fox 87-93 Battery Top Sticker? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 7
pete_05_gt Upr Battery Relocation Help Fox 5.0 Mustang Tech 7
M New Owner Many Issues. Help!!!! SN95 4.6L Mustang Tech 3
C Alternator Or Battery? Need Help 1996 - 2004 SN95 Mustang -General/Talk- 4
Caydink1998 Please Help! Battery Problems..? The Welcome Wagon 3
D Electrical Help! Can't Tell If Tranny Or A Battery Problem. Fox 5.0 Mustang Tech 1
B Electrical Need Help Relocating Battery On 94 Cobra Fox 5.0 Mustang Tech 2
KyleEBK Car Has No Battery In Front.i Want To Get 1 In There. Help Fox 5.0 Mustang Tech 7
C Need Help Cant Get 2014 Into Neutral Dead Battery 2005 - 2014 S-197 Mustang -General/Talk- 1
Night Shifter need help bad! can a bad battery cause this? SN95 4.6L Mustang Tech 17
Night Shifter Lightweight race battery help SN95 4.6L Mustang Tech 8
D help with dead battery in my truck 2005 - 2014 S-197 Mustang -General/Talk- 1
T 84 5.0 battery being drained. help? Fox 5.0 Mustang Tech 5
xMalignancy Battery problems maybe ..plz help Fox 5.0 Mustang Tech 1
xMalignancy Battery Problems maybe? help 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 2
B help, key left on when battery connected = no start now Fox 5.0 Mustang Tech 1
8 help with battery box Fox 5.0 Mustang Tech 2
P Help locating a battery drain SN95 4.6L Mustang Tech 26
B Help needed for some last minute hardware! Shroud to body and battery tray to body Fox 5.0 Mustang Tech 0
0 Help! Mustang draining the battery fast when its sitting in the garage!? SN95 4.6L Mustang Tech 9
I Dead battery light is turning on and off HELP!! PLEASE!! SN95 4.6L Mustang Tech 9
J alt overcharge fried battery? help!! Fox 5.0 Mustang Tech 9
K Help relocating battery Fox 5.0 Mustang Tech 7
98stangv8 Battery light coming on now...help! 1996 - 2004 SN95 Mustang -General/Talk- 0
G Battery Light backwards Please help!! SN95 V6 Mustang Tech 2
steedastangt battery relocation kit - need help SN95 4.6L Mustang Tech 2
C Amperage draw from battery, help needed!! SN95 4.6L Mustang Tech 1
R Battery not charging/not starting/car shutting off ... help... Fox 5.0 Mustang Tech 5
C Help: Battery Problems Fox 5.0 Mustang Tech 1
'88Cobra Please Help! Negative Battery Cable Question Fox 5.0 Mustang Tech 9
J Battery cables - please help SN95 4.6L Mustang Tech 10
beenstanged BATTERY TRAY please help 1974 - 1978 Mustang II Talk & Tech 2
1 HELP - shes eatin batteries! Fox 5.0 Mustang Tech 5
M Battery/Alt problems.. HELP! Fox 5.0 Mustang Tech 1
A HELP!!! battery wont hold a charge... Fox 5.0 Mustang Tech 3
