HELP!!! Bog on acceleration, erratic idle!!
ARTTII
272
Detroit, MI
I have a 93 mass air EFI application on my Mustang. I have an erratic idle (surging up and down, engine shakes), and a big bog/delay/engine stumble on acceleration. If you hold it at a higher RPM the engine is smooth and does not missfire or shake... I have had everything apart and now got it back together, anbody got an idea what I should check first????
thanks
PUll the codes to start.
On another thread, didnt you just attribute the issue to the temporary lack of lambda sensors?
Good luck and bump.
