  • SN95 V6 Mustang Tech
Help-cam synchronizer-new problem
  • Thread starter Thread starter smokdivr28
  • Start date Start date Jan 23, 2011
smokdivr28
  • Jan 23, 2011
I realize that these synchronizers are a recurring theme, but I have searched the forum and can't seem to find an answer, or the exact same problem. I have an 04 Mustang with the 3.9. About 2 weeks ago the synchronizer started raising hell. I didn't get any chirping ahead of time or anything, it just started screaming. Anyway I get a new one from Napa ($199-makes me wish I had the 3.8) which came with the new sensor included. I had talked to a mechanic prior to trying the install and he told me that I could mark the locations of the old unit and line everything back up exactly to avoid my concerns about not finding exact TDC. I did that and the car seemed to run fine, but after a few hours I got a "service enging soon" light. Went to Advance Auto and sure enough the code was for the synchronizer. Assuming I got something off a bit, I researched TDC and set it, then used the tool that came with my new part and installed it correctly. Car ran great again, for about two days. It started to jerk around 35-50 mph and then finally threw a flashing trouble light. I took it to a trusted mechanic and he hooked up his reader and we got a no. 1 cylinder misfire. We pulled the no. 1 plug just to see if I bumped it or something during reinstall and found nothing. We also used a spark tester and the no. 1 was firing it's butt off. As of now, the car is still at the shop and he can't seem to diagnose the cause of the jerking. The service engine light has not come back on, and he rechecked the installation of the synchronizer and it is good. One thing I forgot to mention; the new sensor that came with the synchronizer would not plug into my wiring harness. It looks almost identical, both are two prong, but the male connectors on the sensor are just slightly larger than the female connectors on the harness. Instead of altering a bunch of stuff I just used the old sensor since it was the bearing of the synchronizer that was bad. Any ideas would be tremendously appreciated. Sorry for the length of the post. Thanks.
Skymarshal
572
Dallas
Jan 23, 2011
  • Jan 23, 2011
Are you absolutely certain your synchronizer was the correct one for your car? I think it's very unusual to have a sensor that isn't an exact match. Even if you reuse the old sensor, the new synch might have slightly different measurements that are meant for another year.
I have had auto parts stores give me a part that they swear up and down is the right one, and a brief search on the internet by me shows that it's not. Their computers and inventory systems aren't infallible.
smokdivr28
  • Jan 23, 2011
I have been thinking along those lines myself, and you certainly can't tell from just looking at the thing. It will be tomorrow before I can get back into my mechanic's shop to check. The sensor not being an exact match is kind of incriminating I think.
smokdivr28
  • Jan 23, 2011
I still have the box the part came in, it is a Napa CSU103, but I haven't found much info on the net about it.
Questions Replacing Cam Synchronizer
  • Blackout67
  • Jul 6, 2025
1996 - 2004 SN95 Mustang -General/Talk- Dec 23, 2025
01cstang
Problems after exhaust install and 02 harness
  • djj62478
  • Jul 2, 2026
AeroCoupe
A
P0036 P0056 P0137 P0157 2020 Ford Mustang GT
  • AmkoA
  • Jun 16, 2026
  • 2024+ (S650) Mustang -General/Talk
2024+ (S650) Mustang -General/Talk Jun 16, 2026
AmkoA
A
J
Exhaust manifold to Y-pipe nut & stud dimensions?
  • joeybuddy96
  • Jul 7, 2026
SN95 V6 Mustang Tech Jul 9, 2026
joeybuddy96
J
  • dan50
  • Jul 18, 2026
dan50
