I need some help to figure out what's wrong with my car. The problem is that it bogs down and backfires. I'll drive and it will bog down usually only do it under 1500 rpm at lower speeds. Then it will backfire and drive normal, it backfires throught he exhaust. Sometimes it just bogs down with no backfire and then pick up as if nothing is wrong. This happens for about 15 minutes before the CE light comes on. Once the CE light comes on, it stops bogging down and backfiring. Problem is, once I turn the car off and back on again the CE light isn't on anymore so I can't get that code. I've checked for codes anyways but the scanner shows nothing with KOEO or KOER tests.
So far I've changed: plugs, fuel filter, air filter, new distributor w/module and pickup, coil, tps, and IAC but the problem is still there.
The car is stock only with after market exhaust. Any suggestions or help would be appreciated.
