Hey guys, well basically what the title says. Whenever I turn on the heat or the AC my car idles High then Low then high again and doesn't stop. Does anyone know what this might be?
Thanks
Thanks
Kilgore Trout said:Nah, the problem is low freon.
sgarlic said:You sure it does it with the heater on? I would say clean or replace the IAC valve, but there isn't much increased load on the engine itself (except maybe the alternator,) with the heater that the IAC should be compensating for. Did you mean it does this on defrost?
MainstreamStang said:OK, when the heater is on, it DOES NOT happen, only when the AC is on or the Defrost is on (either hot or cold). Still Freon or IAC?
Edit: I just remembered I replacced the IAC last year, I will try the FREON, thanks!
