Help Car Is running really Rich when cold
NXSTANG
18
SoCal
So It started doing It once in a while but now It's every Morning It runs really Rich It pops thru the exhaust and my A/F gauge Is pegged out on rich and Fuel Pressure is were I left It any Ideas what should I check first there is no check Engine Light on and I have'nt done anything to It(Mods) in a while Thanks.
Still start with pulling codes. They can be stored without the CEL being on or having been on.
What A/F ratio are you seeing?
If using a Narrowband gauge, it will take a minute to light-off. An issue is that the car runs rich during warm-up and the NB can't see outside it's narrow range to tell you much.
Good luck.
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
attachment.php
See http://www.troublecodes.net/Ford/
OR
See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see http://www.midwayautosupply.com/pc-7208-90-equus-digital-ford-code-reader-3145.aspx – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $35.
