help, car wont start after head swap
hey guys, well looks like I found the problem, I performed a compression test and the results are as follows:
#2=0
#3=20
#4=10
#5=120
#6=100
#7=0
#8=0
What does this mean, did I screw my new afr's, the car never started but tried to start.
PRO50SC said:
Have you checked the compression yet??? :shrug: :bang: :bang: :bang:
Does it sound abnormal when you crank it. Did you check the valve to piston clearence before hand? Maybe those 1.7 rockers pushed the valves open to far and you bent the valves. You've tested all kinds of things but I have seen no mention of a compression test.
Sounds like we have a winner, I believe you may have some bent valves, with thoes new rockers.... :bang:
PRO50SC said:
You only need three ingrediants for a car to start. Spark, fuel and compression. If you have spark and fuel, the next step is to check compression.
Not trying to rub salt in an open wound, but the above was reply #3. Could have saved yourself a whole lot of time testing things for nothing. Looks like those heads are coming back off. Glad you figured it out though. Don't feel to bad, I'm sure all of us have learned the hard way at one time or another. Does help to carefully read peoples posts though. Again, I'm guilty of that as well.
#2=0
#3=20
#4=10
#5=120
#6=100
#7=0
#8=0
Where's #1? Yes. (answer to your question) Engine didn't need to start to bend the valves. As soon as cranking started the pistons started beating the valves. One last thing to try before yanking the heads. Loosen all the rockers so there is no tension on the valve springs and do the compression test over. If you now have compression, the rockers are holding the valves open and causing lack of compression and most likely the valves are ok. If you still have no compression, then you're screwed.
jrichker said:
Cranks OK, but No Start Checklist for Fuel Injected Mustangs
1.) Remove push on connector from starter solenoid and turn ignition switch on. Place car in neutral or Park. Remove coil wire from distributor & and hold 3/8” away from engine block. Jumper the screw to the big bolt on the starter solenoid that has the battery wire connected to it. You should get a nice fat blue spark.
A.) Coil
B.) TFI module
C.) PIP sensor in distributor
D.) ECC relay next to computer - look for 12 volts at the fuel injector red wires
E.) Fuse links in wiring harness - look for 12 volts at the fuel injector red wires
F.) Ignition switch - look for 12 volts at the fuel injector red wires
G.) Computer
2.) Spark at coil wire, pull #1 plug wire off at the spark plug and check to see spark. No spark, possible failed items in order of their probability:
B.) Distributor cap
C.) Rotor
D.) Spark Plug wires
Two reasons:
If it starts then, you have a fuel management issue. Continue the checklist with emphasis of fuel related items that follow. If it doesn’t ,then it is a computer or timing issue: see Step 4.
Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 5-20 seconds and shut off. To trick the fuel pump into running, find the ECC test connector and jump the connector in the lower RH corner to ground. See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html for a description of the test connector. If the relay & inertia switch are OK, you will have power to the pump. Check fuel pressure – remove the cap from the schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. Beware of fire hazard when you do this. In pinch you can use a tire pressure gauge to measure the fuel pressure. It may not be completely accurate, but you will have some clue as to how much pressure you have.
No fuel pressure, possible failed items in order of their probability:
C.) Clogged fuel filter
D.) Failed fuel pump
E.) Blown fuse link in wiring harness. Look for 12 volts at the Orange/Lt Blue wire on the fuel pump relay
F.) Fuel pressure regulator failed. Remove vacuum line from regulator and inspect for fuel escaping while pump is running.
Fuel pressure OK, the injectors are not firing. A Noid light available from Autozone, is one way to test the injector wiring. I like to use an old injector with compressed air applied to the injector where the fuel rail would normally connect. I hook the whole thing up, apply compressed air to the injector and stick it in a paper cup of soapy water. When the engine cranks with the ignition switch on, if the injector fires, it makes bubbles. Cheap if you have the stuff laying around, and works good too.
A.) Pull an injector wire connector off and look for 12 volts on the red wire when the ignition switch is on.
B.) No power, then look for problems with the 10 pin connecter (salt & pepper shakers at the rear of the upper manifold).
C.) No power and the 10 pin connections are good: look for broken wiring between the orange/black wire on the ECC relay and the red wire for the 10 pin connectors.
4.) Spark & fuel pressure OK.
A.) Failed IAB (no airflow to start engine). Press the throttle ¼ way down and try to start the car.
C.) Engine ignition or cam timing off only likely if the engine has been worked on recently).
Waste of time. Nowhere in this trouble chart did it ever mention checking for compression. Gotta start with the basics otherwise it will get you everytime.
