Help car wont start.
chito'stang
Hi,
Hopefully someone could help me out. First i have a 96 Mustang that i did an engine swap to a 95 5.0L. during this process i replaced the wiring harness from a 95 GT. now i don't hear the fuel pump when i turn the ignition switch. i thought it was a bad ground or the fuel pump relay. any ideas??? please be helpful cause i'm running out of time, my wife got into a car accident and this our only car left.
i'm using the CCRM from the 95 mustang GT. ford part#F6ZF12B577-AA. I tried both parts on a friends SN95 and it started right up. i just wanted to eliminate these components before looking into a wiring problem. any ideas are welcome.
Ok first of all if its a crank but no start and you think its the fuel pump. Something easy to do. Go to the trunk and check power to the fuel pump. Be sure its getting power first. If it is then check the ground side of it. If you have power and ground then you might want to look into getting a new fuel pump. If it doesnt even crank the fuel pump is the least of your worries. Get back to us and let me know what you find out, I might be able to help you out a bit more.
It sounds like you need to get this car up and running. You would need to provide some useful info about what the exact issue is with the car. I have no idea if it cranks but won't catch or if it won't even crank.
Be specific and the smart folks in here can offer assistance to help get you up and running.
a little more detail on this starting demons. the car cranks but wont start. i dont hear the fuel pump priming. I hear the CCRM clicking when i turn the start switch to run. i haven't done any further troubleshooting. i know the first problem is the pump not priming and i'm very sure it has to be an electrical issue. i will get a chance to work on it this afternoon so any suggestions are welcome.
I'd check to see that CCRM Pins 12 and 24 show 12 volts with the key on.
Also check CCRM Pin 5 for 12 volts with the key on *and during the period the FP would be priming out*.
guys thanks i check the pins that you guys said to check for 12v. and i was not getting anything coming out of pin 5. change the ccrm and my engine is running. However, i encouter another problem my transmission goes in gear but the car just won't move? this is a 5spd t-5. i used the driveshaft from the V6 you think that could be causeing a problem?
