Help Cold Start Stalling
JTrueBlue
I have a 2001 Mustang GT, when cold start occurs, and I simply let the engine warm up like normal, after doing so I put my car in drive ( yes its an auto, and when its put into drive, the rpm will change a bit ) so I get a loud droning noise from the front of the car, for about 10 seconds this noise will occur, and my rpms will rise a little over 1100, and then it will stall out completely, but then after i start it again, it will be a normal working car. I've checked my belt and all the accessories running from the belt, no sign of wearing at all. Ive had a mechanic look at it and they cant figure it out, I have a video of the noise to show you guys what I mean by it.
  • Sponsors(?)
JTrueBlue
I believe so, i mean it makes sense to me, same type of humming noise that others are talking about that has to deal with IAC system, I probably plan on just replacing all the air system by throttle bottle, getting a cold air, and new iac should just solve all the problems
wmburns
SN Certified Technician
Aug 14, 2009
5,825
501
194
Houston Texas
By chance did you remove that square box that is inline with the IAC bypass line?
Note, the purpose of that square box is to reduce resonance noise.
Thread starter Similar threads Forum Replies Date
silverlx50 Engine UPDATED WITH FIX IN POST #49 Help with sputter issue with cold starts Fox 5.0 Mustang Tech 49
0 2003 Ford Mustang V6 3.8L gets around 12mpg and seems to shake a bit when started cold and has a bad rough idle when warm SN95 V6 Mustang Tech 5
Keith5.0GT Cold Start And Koer Help Fox 5.0 Mustang Tech 33
M Fox 1991 Mustang Gt No Start When Temp Is Below 50f. Need Help 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 9
camaroguy72 Help Needed- 95 Mustang Gt Intermittent Cold Start Issue, Rpm Drop Randomly On Highway 1994 - 1995 Specific Tech 24
M 1989 Mustang Gt Will Not Stay Running At Cold Start Up. Please Help! Fox 5.0 Mustang Tech 15
T ID this connector, and help with cold start stumble needed Fox 5.0 Mustang Tech 11
evil281 Need Help, Cold start issue SN95 4.6L Mustang Tech 1
SMOKEDYA HELP WITH COLD START Fox 5.0 Mustang Tech 15
SpazLE995 Help!! Pony Stutters when cold start and WOT SN95 4.6L Mustang Tech 30
R Need help w/ lean running / cold start issues Fox 5.0 Mustang Tech 21
BensBACobra Ticking noise comming from engine on cold starts. Plese Help SN95 4.6L Mustang Tech 30
9 Cold Starting Then Bogging Problem HELP 2.3L (N/A & Turbo) Tech 0
94twistgt cold start idle help!?!?!!? 1994 - 1995 Specific Tech 10
S Help! Cold no-start problem on 2.3 N/A 2.3L (N/A & Turbo) Tech 11
tsoccer3299 dosent want to start when cold. help? 1994 - 1995 Specific Tech 19
H Cold Start Sucks, HELP... 1994 - 1995 Specific Tech 4
C No Oil Pressure On Cold Start???? Knock Knock Knock Knock!! Help Fox 5.0 Mustang Tech 11
7 Cold air intake help 1996 - 2004 SN95 Mustang -General/Talk- 0
Ron90LX Engine Cold air intake help needed. Fox 5.0 Mustang Tech 20
Troublesome_Hobby please help - hot/cold climate controls don't work, only blows hot air 2005 - 2009 Specific Tech 4
cutecrimnal143 Tune Help With Mustang Gt And Color 1996 - 2004 SN95 Mustang -General/Talk- 4
clyons Drivetrain Transmission Slips When Cold...help 2005 - 2009 Specific Tech 3
M HELP New starter and disengaging and running rough when cold Fox 5.0 Mustang Tech 2
5.0_GT_kid Troubleshooting help needed. 89 LX won't run, driver side headers cold. Fox 5.0 Mustang Tech 5
JasinC19 Car is running cold... been through 2 stats. Help? Fox 5.0 Mustang Tech 14
U Just bought a 2010 GT, I want a Hp increase= Exhaust and cold air intake? Help 2010 - 2014 Specific Tech 4
Nicoleb3x3 Help with intake/cold air for kennebell set up 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 4
R BBK Cold Air help Fox 5.0 Mustang Tech 3
tk_5.0 95 GTS skips at part throttle when cold...HELP?!?!?! 1994 - 1995 Specific Tech 13
B Help! After PI swap, runs great cold, chokes as it warms SN95 4.6L Mustang Tech 17
N BBK Cold Air Intake Help Fox 5.0 Mustang Tech 4
U Help with Cold Air Kit Install parts 1994 - 1995 Specific Tech 15
U Help with Cold Air Kit Install parts 1994 - 1995 Specific Tech 0
the98stang HELP! AC not blowing cold/bad idle SN95 4.6L Mustang Tech 18
topless98gt Help Me Decide: H&R Springs OR JLT Cold Air Intake? 1996 - 2004 SN95 Mustang -General/Talk- 13
N Help Car Is running really Rich when cold Fox 5.0 Mustang Tech 3
toolrk Runs great cold - hesitates and bogs when hot!! Help!! 1994 - 1995 Specific Tech 11
BensBACobra Strang ticking noise upon cold startup. Need help. SVT Tech Forum 16
P QUICK help with 76mm mass air and cold air kit Fox 5.0 Mustang Tech 6
J Bad Idle, Bad Cold Running, Pulled codes, Need help Fox 5.0 Mustang Tech 6
D cold relay help Fox 5.0 Mustang Tech 1
88306stang Help installing cold air intake Fox 5.0 Mustang Tech 4
Final5pt0 cold air intake help! 1994 - 1995 Specific Tech 12
tsoccer3299 the car not help with running right when its cold? 1994 - 1995 Specific Tech 1
G Help with the different Cold Air kits!! Fox 5.0 Mustang Tech 6
8 transmission slips when engine is cold? HELP. Fox 5.0 Mustang Tech 3
J Cold Air Intake HELP!!!! SN95 4.6L Mustang Tech 20
S K&N Gen II Cold Air Intake owners help SN95 V6 Mustang Tech 11
9 Cold air intake help??? Fox 5.0 Mustang Tech 2
