I just bought an 84 gt that has had an 86 5.0 ho put in it minus the intake. The car has had an aod from the same 86 model installed also. The motor and tranny only have 38k on them. I have been told that hooking up the aod's detent cable or whatever it is can be a pain on a carb. I heard that if not hooked up right the tranny will burn up. I also need to know what is needed to put a carb setup on the motor. I know i will need an inline fuel pump. The car came with an old two barrel carb and intake to use. I may have to use this if money won't let me get a 4barrel setup. If anybody has completed this swap and has any helpful information to share it will be greatfully appreciated.
