Just like someone posted earlier,i also have a coolant leak in my car. First it was about 1 to almost 2 months till my coolant light came on. Then it got down to 1 month and the coolant light came on with no signs of leaks. I found out that my hose from the heater core to the water pump was leaking cause i saw it drip onto valve cover,so i replaced it. Now after i see coolant under that car,but i have no idea where its coming from. Some how there a small tiny puddle of coolant that to the lfet side part behind the water neck and above the water pump. Could it be a gasket leak? and what tests can i do to find this leak,it getting real annoying and expensive adding coolant all the time. Will a pressure test find the leak?
